Swiftune Or Morspeed Engines?
12 replies to this topic
#1 aznsurfer
aznsurfer
  • 91 posts
  • Local Club: hmo
Posted 27 October 2007 - 01:02 PM
i going to get a 1380 road engine. which do you think is better, swiftune or morspeed? swiftune says it will cost about 5000gbp for a complete engine. is this reasonable?
#2 Jammy
Jammy
  • 25,397 posts
Posted 27 October 2007 - 01:04 PM
Well Swiftune are being very picky at the moment about building road engines, and Morspeed can have long lead times. Both will be able to build you a top notch engine though.
That £5000 is completely irrelevant unless you tell us what your getting for that money.
#3 aznsurfer
aznsurfer
  • 91 posts
  • Local Club: hmo
Posted 27 October 2007 - 01:41 PM
1380cc motor with our SW5 and Hi-Lift rockers, Rocket
cylinder head, Powermax pistons, hardened crankshaft, balanced, steel
mini
flywheel and clutch, 123 electronic dizzy, steel harmonic damper, ARP
hardware, Rebuild helical gearbox with centre oil pipe and 4 pin diff
unit,
choice of final drive. Built in to an A+ engine and gearbox unit, Dyno
run-in and set up for maximum performance with a new HIF44 carb
assembly
with K&N filter. The engine ready to use... No running in or Rolling
road
tuning required.
Total power out put will be 100 BHP @6000 with 100 ft/lbs Torque @ 4000
RPM
all with a super smooth idle and great drivability.
The total price for the engine will be £5150 with no Vat.
Does it seem a little pricey without omega pistons?
#4 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 27 October 2007 - 02:48 PM
Swiftune engine is by far the better engine, hence the price. It's built, set up and run in, all you do is fit it. Dont forget that this is 'complete' IE it comes with the carb as well
#5 redhotmini
redhotmini
  • 1,607 posts
Posted 27 October 2007 - 07:30 PM
the swiftune unit it essentially a ready to use properly engine. because they run it in for you they can usually identify any problems before it ends up in your car. i dont think there is any other engine builder that does that for you.
#6 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 27 October 2007 - 07:46 PM
Well, the only question you need to ask yourself, is how long do u want to wait, and what cam do you want...
MSPD, do build good engines, spesh if your on a budget, whereas Swiftune, build excelant engines too.
I personally, would go Swiftune, but, £5 thats quite alot of mooolaaa... thought about building a 1380 yourself?
Its really easier than people think, get a copy of "Ultimate Mini, 1380 engine builder". You'll see how it goes together, and how easy it is. I've just built my 1380 to a simuar spec to the Swiftune eninge you've quoted, but with twin carbs, on decent manifolds, in the car, ready to rock, for £3000....
#7 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 27 October 2007 - 07:54 PM
Have you tried ringing MED or Slark?
Slark are VERY good at what they do.
otherwise do what dog said, build your own. buy a kit from an engine supplier and add fancy bits to your taste.
#8 mk1leg
mk1leg
  • 9,343 posts
Posted 27 October 2007 - 10:08 PM
my swiftune motor was dyno run in and all i did was install it in car and 2hrs laler having great fun and trying not to lose my licence, best A+engine on the market, you get what it says on the can a B****y good engine that goes................ :ermm:
#9 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 27 October 2007 - 10:14 PM
There is no comparison! Swifty every time. I will not go to anyone else, I get on with Nick, Phil and all down there. It doesnt matter what the price is as quality, dyno results and sheer speed will always be far superior than any other.
Paul
#10 fastcarl
fastcarl
  • 344 posts
Posted 27 October 2007 - 10:26 PM
Paul
i on the other hand wouldn't give swiftune one penny of my hard earned, sure they make great engines, but some years ago i had a breif encounter with Nick swift, and came away with the distinct impression he was a cocky self righteous git.
he wouldn't recall the breif conversition , but i surely did,
these are my personnel experiences and should not influence anyones thoughts,
carl
Edited by fastcarl, 27 October 2007 - 10:27 PM.
#11 Paul Wiginton
Paul Wiginton
  • 1,585 posts
Posted 28 October 2007 - 09:30 AM
Paul
carl
I can understand that Carl, he is a bit like that.
Gavin had a MED head on his Speedster (full race spec as you would guess), but I beat him that year so he put on a Swifty head the same as mine and gained 14bhp on the same rollers (Southern Carbs). I think that says it all.
Ive been dealing with Swifty for 9 years now and have broken through to his friendlier side. He still says "What the F**K do you want? you C**t." when I phone him, but thats what extreme southerners are like.
Paul
#12 Pie
Pie
  • 7,695 posts
Posted 28 October 2007 - 10:05 PM
lol whilst we are giving opinions lol
Morspeed, arent in my good books at the moment, been ringing and ringing, but no answer, leave messages, no calls returned, and i live too far away to "pop-in"
So slark will always get my money. Brian is a legend, he will suggest things and if you dont opt for them, isnt offened, and always does his best work.
#13 nmt_oli
nmt_oli
  • 460 posts
Posted 28 October 2007 - 11:20 PM
Slarky have always been very helpful when ive popped along, only spoken to niel though. did a dyno run on my golf.
Im getting an engine from morspeed atm, as it was a bargain on there used section, and i know they do good stuff, but they are being VERY slow. over 2 months overdue- fully paid up 3months ago. even said it was in the post a week before coombe, and it hadnt even been on the dyno! aparently that was the dyno guys fault though.
