Overfilling oil?!
Posted 26 February 2005 - 10:28 AM
Posted 26 February 2005 - 10:31 AM
Posted 26 February 2005 - 10:45 AM
Posted 26 February 2005 - 12:45 PM
Posted 26 February 2005 - 12:51 PM
howz your new engine running?
Posted 26 February 2005 - 01:26 PM
I think I've burnt the excess oil now anyway as car seems a lot happier, will check later though, will be funny if it has burnt it off in the space of a day!! I couldn't of travelled more than 20 odd miles!!
Posted 26 February 2005 - 01:29 PM
it shouldnt burn any oil at all! lol should practicaly start its self! lol
Posted 26 February 2005 - 01:42 PM
I didn't think it would use much oil then, after running it dry going to West Sussex and back (via Portsmouth, accidently), I phoned Bill and checked. he said its designed to burn oil, asnd should go through about 1 litre every 150 miles.
Sounds odd I know, the only reason I can think of it doing this is for heat dissappation?!
Posted 26 February 2005 - 02:22 PM
Finally if you're using Omega forged pistons, that would also explain the high oil consumption since they're known for letting oil pass through without too much fuss... part of their design... go figure
Posted 26 February 2005 - 02:42 PM
Posted 26 February 2005 - 02:58 PM
Posted 26 February 2005 - 03:07 PM
May I add that it was quite old (around freezing) when I was driving and it was sluggish), need to check whether I have the hose connected to the inlet manifold.
Posted 26 February 2005 - 06:13 PM
What's your crank case pressure like ?
Posted 26 February 2005 - 06:34 PM
OK, don't know how to check just the crank case pressure, but my oil pressure gauge sits at 80 usually, sometimes heading up to 90.
