Burlen Fuel System
Posted 28 February 2005 - 05:23 PM
Does anyone here know what is included in these kits: (carb id: FZX 1415)
CRK 121 Rebuild kit
CRK 65 Service kit
CSK 003 Sundries kit
Jackman
Posted 28 February 2005 - 06:50 PM
You can get what's called a full repair (rebuild) kit which includes, butterfly, spindle, all gaskets, gromets, jet, floatchamber valve etc... which will be iro 50 quid
You can get a service kit , which is as above, but does not have the butterfly or spindle, but has jet, gaskets gromets, iro 25 quid
Normally with a carb which is on a car, you'd get away with a service kit, the rebuild is only realy required when bits are missing, or the bushes are worn.
Cant say that I know what is in the sundries kit... as never used one.
Posted 28 February 2005 - 06:56 PM
The gasket kit has: engine and air inlet gaskets, float lid gasket, damper piston washer (if fitted) and jet tube seal and washer.
The service kit has all that plus: float chamber needle valve, jet and jet link clips.
The rebuild kit has both of those plus: throttle spindle, throttle spindle bushes, throttle disc, throttle securing split screws.
That's it, any other missing screws, clips, levers, washers or anything else you need will have to be ordered direct from BFS by part number.
Get a copy of the Burlen Bible, it has exploded diagrams of all the carbs and lists of all the parts available for all makes and all setups. I got this info from my copy, it's ver worthwhile having.
Posted 28 February 2005 - 07:57 PM
by the way Dan, the info i got was off the e-mail sent to me.
Posted 28 February 2005 - 10:19 PM
FZX1415 -
Gasket pack AUE811
Service kit CSK65
Reduild kit CRK121
It might be that the sundries kit has all the little screws and springs and stuff, so try to ask them what's in it (again!). If it helps, never ever talk to the first people who answer the phone there. They tend to be temps. I always ask for the technical department as they actually know things.
If you really need a new throttle lever (you might find your current one will be a tighter fit on a new spindle) then you may have trouble finding one. AFAIK they don't come in any of the packs (unless they are in the sundries pack) and there are dozens of different types to choose from. You may end up having to fax them a picture of your current one so they can match it.
I always buy Burlen stuff direct from them over the phone, no mark up and they understand what you want.
Posted 28 February 2005 - 11:02 PM
Posted 28 February 2005 - 11:27 PM
01722 412500
Posted 28 February 2005 - 11:29 PM
Posted 03 March 2005 - 09:41 PM
Dear Sir,
Service and Rebuild kits
SU Carburetter Service kit
An SU Service kit contains:
Gaskets
Seals
Jet
Float Needle Valve
SU Carburetter Rebuild kits
Gaskets
Seals
Jet
Float Needle Valve
Throttle Spindle
Throttle Disc
Disc Screws
Bushes
Hope this information is useful for you.
Kind Regards
For and on behalf of Ray Choules
Customer Services
Posted 05 March 2005 - 09:42 AM
