Carb Spray
8 replies to this topic
#1 D3nch
D3nch
  • 422 posts
  • Local Club: "The Boys are Back"
Posted 08 November 2007 - 01:19 PM
Hi
Has anyone heard of carb cleaning spray?
I saw some, in my local parts shop. It is in an aerosol can, and you are ment to spray it into the carb when the engines on.
Anyway, Im about to rebuild and service my HS4's and was wondering if this is a suitable spray to use, or weather this is just a spray to use when the ending is running (as directed on the tin)
If not, what is the best thing to clean the carb up with? petrol??
Add
#2 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 08 November 2007 - 01:26 PM
Carb and choke cleaner is OK (frost's I think) to use or the parts washer at work!!
#3 D3nch
D3nch
  • 422 posts
Posted 08 November 2007 - 01:44 PM
parts washer?
what about WD40 or Petrol???
Surely petrol wont harm a carb ;-)
My carb kit hasnt come today tho >_<(
Add
#4 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 08 November 2007 - 01:56 PM
Yes I can use a parafin based parts washer in the workshop at work. It is great for cleaning stuff as it degreases an cleans.
Petrol is OK but not that nice to work with. WD40 can leave a residue but I am siure it would be fine for carbs though.
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 08 November 2007 - 02:11 PM
If you're talking about doing a major cleaning of your carb(s), the stuff in the spray can will work just fine without the engine running. Over here you can also find carb/parts cleaner in 1 gallon metal "paint" cans and inside is a dip basket so you can soak parts in the solvent.
Gasoline and WD40 are not effective at cleaning carbs. Buy the spray or dip carb cleaner. It is amazing how quickly it will work. I find applying some of the solvent and using what we call and "acid brush" to scrub it in works amazingly well. An acid brush is usually used by plumbers to apply flux to copper pipes. It's a disposable mini paint brush with a tubular sheet metal handle with boar bristles crimped in the end. Cheap, unaffected by solvents, and disposable. Use the brush to scrub the carb cleaner into the nooks and crannies, then flush the parts with a spray of carb cleaner to wash away what you've dissolved.
by the way, you can spray the carb rubber and plastic parts with carb cleaner. HOWEVER, do NOT soak rubber and plastic parts in the carb cleaner as they will be damaged. Spray, rinse, and blow the plastic and rubber parts dry.
Edited by dklawson, 08 November 2007 - 04:40 PM.
#6 D3nch
D3nch
  • 422 posts
Posted 08 November 2007 - 02:23 PM
Mr Lawson sir, you are a good man..
Add
#7 ian
ian
  • 676 posts
Posted 08 November 2007 - 04:55 PM
you could always try looking in your local pound/cheapy shop.
they do carb cleaner in a blue tin, when i see it i normally clear their shelf of the stuff, its great for cleaning loads of stuff.
just dont spray it on grass or plants, it kills them in seconds
#8 cap'n crunch
cap'n crunch
  • 1,060 posts
  • Local Club: .
Posted 08 November 2007 - 05:41 PM
i used petrol and a toothbrush to clean my twin HS2 and it worked a treat!
Edited by cap'n crunch, 08 November 2007 - 05:42 PM.
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 08 November 2007 - 06:09 PM
That works great on the loose stuff (particularly on the outside) but it won't touch the brownish gum and varnish that builds up from old fuel. If gas would clean that off, it wouldn't form in the first place.
