Pre 1989 Mg Metro Final Drive
12 replies to this topic
#1 Chewy
Chewy
  • 162 posts
  • Local Club: Leamington Spa Mini Massive
Posted 08 November 2007 - 10:27 PM
Hey all
Does anyone know what final drive is when i am doin 50 it revs really high and i am 10 inch minilites
would it help if i was on 12's
help
My engine number is 12HD24 112523
Edited by Chewy, 08 November 2007 - 10:34 PM.
#2 minimanclive
minimanclive
  • 1,108 posts
  • Local Club: LSMOC
Posted 09 November 2007 - 01:25 PM
The MG Metro and most Metros had a 3.44:1 final drive. There's not much difference in the rolling radius between 10 and 12 in wheels to make a big difference to your engine RPM. You'd still be looking at over 4000rpm at 70mph. If it's reving higher than that then it could be your clutch slipping.
#3 Ethel
  • 26,112 posts
Posted 09 November 2007 - 02:03 PM
Download WinSU - you can play around with different ratios and tyre sizes.
Not sure if the later MG Metty's didn't use 3.2 diffs ???
3.44 diffs were used on 10" wheeled Minis for many years.
#4 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 09 November 2007 - 02:10 PM
Hey all
help
you dont say what gear :shifty:
what do you call really high?
#5 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 09 November 2007 - 02:18 PM
mine does 90mph at 5000 rpm and im running a metro lump but had to chance the speedo drive in the box. 90 mph at 5k is right as the guy on the RR said it topped out at 90 and was pulling 5k :shifty:
#6 Jammy
Jammy
  • 25,397 posts
Posted 09 November 2007 - 03:49 PM
Guessworks has a gear ratio calculator thingy ma bob on his site too.
#7 Chewy
Chewy
  • 162 posts
Posted 09 November 2007 - 05:35 PM
ok But it feels a bot low geared could i change the diff from the 1275 a+ from my other engine with out taking to g-box a part
what size wheels were the mg metros
#8 adam25
adam25
  • 33 posts
  • Local Club: Birmingham
Posted 09 November 2007 - 09:46 PM
12.5 Metrics
#9 Chewy
Chewy
  • 162 posts
Posted 02 December 2007 - 07:09 PM
I have fitted a rev counter 2 day me and a mate drive down to northampton and we were doin 70 Mph @ 5500 RPM this is not a 3.44 diff my mini club mate said that is could be a 4.1 or a 4.7 is this i dont knwo anything about diff ratios
The engine is really screaming when doin 70 mph what diff could i put in it
Edited by Chewy, 02 December 2007 - 07:10 PM.
#10 Ethel
  • 26,112 posts
Posted 02 December 2007 - 07:45 PM
It doesn't sound like it has the original diff!
Swapping to 12's won't make more than a few mph difference. Have a look at some of the gear calculator stuff mentioned above. You could run anything down to a 2.7 or 2.95. but you might miss the acceleration >_<
#11 Chewy
Chewy
  • 162 posts
Posted 02 December 2007 - 08:14 PM
Hey
When i bought the engine the bloke said that it has a 850 diff in it
i have got a 3.44 from a 998 A+ would this be a worthwile diff change
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 December 2007 - 10:38 AM
How do you know you were doing 70, and were you in 4th, as I would not be relying on the speedo, 5.5k @ 70 is really short and is not a ratio which is anyway standard to the mini metro or pretty much any stock varient of the A series gearbox...
I believe you'd have difficulty controlling the car in 1st or 2nd without track/slick tyres on.
Get a GPS speedo, and hook a multi meter to the ignition to get an accutate reading of the RPM. I think you'll probably find it's a 3.6 or 3.7 in the end, which means @ 5.5k rpm you'd be cracking 80+ mph, so on a motorway about the same speed as everyone else :ph34r:
#13 Chewy
Chewy
  • 162 posts
Posted 03 December 2007 - 06:47 PM
thanks to you all
My old standard 1275 metro engine had a 3.44 which i prefer it would cruise at 60 with the revs not very loud like it is now
my mini club mate said that i have probably got a 4.1 i donnt know what this means
can i change the diff with out splitting the block from the box i have seen this done be4 its very fiddely
