Welder
7 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 14 November 2007 - 09:37 AM
Hello
I wigh to purchase a gas MIG Welder soon, and have a question about power equirements in my garage. An example of a welder I wish to purchase is a clarke 150TE Turbo. I am looking at getting this from Machine Mart. It is listed as having an amperage of 75, at 60% duty.
I looked at a welding website, and it says most welders up to 150A can be fed from a 13A household plug.
Basically, then, does the domestic circuit in a house need to be uprated to handle a welder of this type, or would the circuits in my house leading to the power sockets be sufficient?
#2 Wil_h
Wil_h
  • 3,244 posts
Posted 14 November 2007 - 09:41 AM
Standard 13amp socket will be fine.
#3 black jack1275
black jack1275
  • 276 posts
Posted 14 November 2007 - 09:42 AM
you dont need to uprate the house suppy is will work fine with the welder you are looking at.
#4 Ethel
  • 26,074 posts
Posted 14 November 2007 - 11:47 AM
A welder is just a transformer really - if you had a 150amp domestic supply you could just stick a a welding rod in the end of an extension lead and weld with that :lol: sounds like a plan for the Darwin Awards.
#5 mk=john
mk=john
  • 1,167 posts
Posted 14 November 2007 - 07:15 PM
Thanks guys
I will jot purchase a welder!. I just had a new garage/workshop built in my back garden (another garage!!!). I have just also bought a 1960 Morris Mini Minor. It is in original, unrestored condition, and the sills and floors have been `patched over the years'. It is MOT, drives great etc etc.
Anyway, at some point next year I will do a strip down on it and my aim is to get it concours. A welder is obviously something I will need!
#6 Austin
Austin
  • 348 posts
  • Local Club: Minis 'n' Oatcakes
Posted 14 November 2007 - 07:26 PM
The 150TE doesent come fitted with a 13 amp plug as clarke recommend a minimum power supply of 16amps, although on car bodywork youre never likely to need to use it at full power anyway. Basically you can fit a 13amp plug and it will work, but clarke dont recommend it. The largest amperage MIG welders machine mart stock that come fitted with a 13 amp plug for a household power supply are 130 amp. This is more than enough for car repairs/restoration. Hope this helps. ;)
#7 mk=john
mk=john
  • 1,167 posts
Posted 14 November 2007 - 07:31 PM
Hi Austin
Thanks for that. Yes, I think the 130 will also do. I have been researching this. Also, what is the minimum amperage I should be looking for to weld thin metal like the skin on a mini? I want to be able to weld panels on obviously, and am concerned that the welders minimum amperagfe wont allow welding of very thin metal.
#8 Austin
Austin
  • 348 posts
Posted 14 November 2007 - 07:44 PM
A minimum amperage of around 30 is okay. Obviously the lower the minimum amps, the thinner the metal you can weld but 30 is fine for body panels. I wouldnt go for one much higher than that. The complete range of 130 and 150 amp maximum clarke welders run at a minimum of 30. At the moment ive got a 151te which im using for all the welding on my project mini and the minimum setting is easily low enough.
