Pros And Cons
7 replies to this topic
#1 crazyride
crazyride
  • 15 posts
Posted 15 November 2007 - 12:55 AM
hi there just need some help been looking on websites for pros and cons of running twin webber carbs on my 998 can some one help! also what air filters and such like would i need?
many thanks
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 November 2007 - 06:53 AM
is this a race engine ?
as its a lot of money for a 998
#3 mini_mission
mini_mission
  • 442 posts
  • Local Club: bumpstart
Posted 15 November 2007 - 11:04 AM
i agree with bumgle, twin webers are overkill IMO even for a highly tuned 998. even on a 1380 it would hardly be justifiable. even a single weber on a 998 is pointless.
but to answer your question, the pros are- an induction noise so fierce it makes you do a little sex wee, and increased bhp IF your engine is tuned to a suitable level to get the most out of the carb.
cons- cost- twin webers are hellish expensive, and a single is not cheap. you will need to buy a fuel pressure regulator, manifold for the carb (longer the better- around 100 quid for a good maniflow one), exhaust manifold if you have a one piece job, cut a big hole in your bulkhead, and your fuel consumption will be unbelievable. my 1380 on a weber 45 manages 16 MPG which means that she drinks half a tank just going to and from the nearest petrol station that sells super unleaded.
oh yeah, and ramp pipes (if they are not fitted already) and a k&n (or similar) filter or sock filters do a good job too, just to add to further expense!
Edited by mini_mission, 15 November 2007 - 11:07 AM.
#4 Jammy
Jammy
  • 25,397 posts
Posted 15 November 2007 - 11:17 AM
A lot of people get mixed up between twin Webers and just a single Weber. With a single Weber there are two barrells that go through the carb and then connect to the inlet manifold, unlike a normal SU which has one throat which then connects to a manifold then splits into two branches. A lot of people see these two barrels and think they are twin Webers.
Real twin Webers are when you either use two Webers (not possible on a 5 or 7 port A series engine, but possible on 8 porters, or non A-series), or you get two Webers and lop one barrel off each carb. This is only really needed on the most firery of fire breathing engines!
A 40 DCOE Weber can work ok on a modified 998, if jetted correctly. Most applications though a HIF38 SU carb would be best for all round economy and performance, or a set of twin SUs for a bit more torque and responsiveness.
#5 crazyride
crazyride
  • 15 posts
Posted 15 November 2007 - 08:54 PM
cheers might not be a good idea for me then as i want to keep prices down just got offered some so wanted to check it was a good idea before i got them
many thanks to all
#6 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 16 November 2007 - 10:22 AM
many thanks to all
How much where they and what did they come off of?
#7 JetBLICK
JetBLICK
  • 1,222 posts
  • Local Club: myspace.com/worcesterretro
Posted 16 November 2007 - 11:31 AM
Real twin Webers are when you either use two Webers (not possible on a 5 or 7 port A series engine, but possible on 8 porters or 7 ports, or non A-series), or you get two Webers and lop one barrel off each carb. This is only really needed on the most firery of fire breathing engines!
Gotta agree with the majority ere. If they're twin split dual choke webers ie, as jammy said each ones got a two barrels and look like this... then thats a bit overkill.
If its just a dual choke weber, a 45 or 40 it looks like this... a 45 would be overkill on a 998 too, and a 40 is only really needed if the engines well tuned, thers nothing stopping you having one, its just that they can be expensive for no real gain in power.
There are single choke webers that they fitted to old fiestas.. they're not worth having... neither are the IDF webers that come off old escorts that some people put on minis.
Basically if its neither of the above, dont bother :lol:
#8 crazyride
crazyride
  • 15 posts
Posted 16 November 2007 - 11:34 PM
ok then thanks to all
