Removing Carb Dashpot
17 replies to this topic
#1 mike.
mike.
  • 6,176 posts
Posted 16 November 2007 - 09:09 PM
I want to polish up my dashpot. But was thinking it would be easier to do it if i could take it off.
Can you take it off? If so how do you drain it? Does it have a rubber seal on it and things?
or should i just do the best i can with it in place?
#2 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 16 November 2007 - 09:32 PM
You can take off the dashpot there are 3 screws holding it on depending on what carb you have. To drain it you have to take the piston off and turn it upside down to get the oil out, it has a tube on the top of it which holds the oil. When you take the dashpot cover off there is a spring there.
#3 Ethel
  • 26,093 posts
Posted 16 November 2007 - 09:51 PM
Unscrew & remove the oil plunger first and you can lift the pot off leaving the piston 'n spring on the carb.
Then you'll be able to wonder at the complexity of the SU carburettor >_<
#4 mike.
mike.
  • 6,176 posts
Posted 16 November 2007 - 10:24 PM
Then you'll be able to wonder at the complexity of the SU carburettor :thumbsup:
But if i just do that and lift it off won't the oil pour out of it?
I don't know whats under there at all so imagine it'd all just pour out.
All i need to know really is if i can jus undo the bolts, the screw top and then jus lift it off, polish it ad put it back on in the same way.Is there any chance of me breaking anything or much chance for error? If so then i'd be best to just not take it off because chances are with me doing it, it will go wrong!
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 16 November 2007 - 10:35 PM
It won't pour anywhere.
The piston holds the oil in a little well. The dashpot just covers it. Thats it really, it's a cover/damper.
#6 mike.
mike.
  • 6,176 posts
Posted 16 November 2007 - 10:45 PM
Right i understand. So nothing can go wrong really?
#7 mike.
mike.
  • 6,176 posts
Posted 16 November 2007 - 10:47 PM
If not - Any tips on getting a nice shine like bud666's dashpot > http://www.theminifo...x...=63912&st=0
#8 GreaseMonkey
GreaseMonkey
  • 3,663 posts
Posted 16 November 2007 - 11:15 PM
You could buy a polished dashpot cover.
#9 mike.
mike.
  • 6,176 posts
Posted 16 November 2007 - 11:19 PM
I can only find red and blue ones though and seem to be for 1275cc+?
Where can i get a polished one to fit my 998
#10 mike.
mike.
  • 6,176 posts
Posted 16 November 2007 - 11:23 PM
oh oh wait - Will this fit? > http://www.minispare....aspx?pid=34113
#11 Ethel
  • 26,093 posts
Posted 17 November 2007 - 01:18 AM
It will if you have a Hif carb. That's the one where the float chamber is part of the same casting, underneath the carb.
#12 Bristolmini
Bristolmini
  • 290 posts
  • Local Club: Northavon Mini Drivers
Posted 17 November 2007 - 01:57 AM
If you have the standard carb for a mini city e (as in your details) then this probably won't fit. YOu will have an HS4 carb instead of an HIF carb. The biggest dofference in the dashpot (the only part you need to worry about as far as covers are concerned) id that the HS4 has a ridge from the main body of the carb to the neck.
I think this is right, it's been a while since I had a 998 but I remember having this problem when I bought a cover (I bought a blue one in the end)
#13 mike.
mike.
  • 6,176 posts
Posted 17 November 2007 - 05:39 PM
Yeah i thought it was a different shape. Anybody know where i can get a cover for a HS4 carb?
#14 blue redtop
blue redtop
  • 1,605 posts
Posted 17 November 2007 - 06:00 PM
post it to me and ill polish it for you,it will look brand new and the shine will blind you.
i polish trumpets french horns flugals and cornets for a living and they need to be mirror finish. :withstupid:
#15 blue redtop
blue redtop
  • 1,605 posts
Posted 17 November 2007 - 06:01 PM
its only alloy.
