Carb Whine/whistle At Mid/high Rpm
Posted 26 November 2007 - 02:59 PM
I've put the original (to this engine anyway) carb back on (a HIF38) and removed the old HS4 (from my old 998). It's a hell of a lot better than the old HS4, but I've noticed a whistling noise from it at about 3/4 pedal travel. If you put your foot down totally, it goes, but lift your foot up again slightly and the noise returns.
I had the same noise with the old HS4 (but it was very knackered so not surprised), except that was about 1/2 way through the pedal travel and you lost power if you stay in that part of the rev range. I don't think this is the case with the HIF38.
Does anyone know what the noise is, or what it indicates?
Just to sum up & try to avoid confusion -
The tempororary knackered carb = HS4, now off.
The original newer carb= HIF38 now on the engine, a late 1275.
Thanks chaps...
Posted 26 November 2007 - 04:57 PM
Posted 26 November 2007 - 05:03 PM
On the HS4, it was just old and very cr@p, so I sort of suspected it to be leaking air in, but not so much on the HIF.
What I forgot, was to say there's a hole on the RH side (throttle link side) above the throttle link, just under the dashpot. It's obviously doing something, because if I put my finger on it, the engine dies, and if not, it runs ok.
Wossit for?!!!
Posted 26 November 2007 - 05:08 PM
Well with a cone you get a massive amount of noise. I used to be able to do the Darth Vader sound with the throttle.
edit
Hole you say? Little hole (2-3mm ish) or big hole (6-7mm)?
Edited by Big_Adam, 26 November 2007 - 05:09 PM.
Posted 26 November 2007 - 06:05 PM
Think turbo diesel at high revs (for a diesel anyway) and thats the sound.
Hole - Yeah, 5-6mm or so. Not a crack type of hole - it's machined and look like itshould be there, but if it's for a breather hose there's no protruding brass tube like you get on all the other carb hose attatchments.
Does that make sense.... if so, that's a first for me
Posted 26 November 2007 - 06:14 PM
Posted 26 November 2007 - 07:23 PM
Posted 26 November 2007 - 09:03 PM
I don't think the hole below and behind that is anything either, but if anyoe can tell me about that too that would be useful. Thanks.
Posted 27 November 2007 - 09:51 AM
"Boing!" Said strebblo...
The others just turned around and stared at his outburst.
Here's where you all chime in: ....
Posted 27 November 2007 - 10:06 AM
Well you got a breather, you got fuel and a overflow fuel pipe.
I'd block the holw up. Bit of resin, take the dashpot off and block one end with some tape, drop of resin down the hole then wait for it to set.
Thats if it goes straight into the carb as a vac feed.
Posted 27 November 2007 - 10:12 AM
Posted 27 November 2007 - 10:16 AM
Out of interest does anyone have this connected to something - is it a gas/emissions sampling inlet?
Posted 27 November 2007 - 10:31 AM
Posted 27 November 2007 - 11:12 AM
Posted 27 November 2007 - 11:26 AM
sorry i can't help, but when you find out what it is, could you let me know please, ta
bb
