Lukeh New Project - Retro Styled Mini
#106
Posted 15 August 2009 - 09:02 PM
#107
Posted 16 August 2009 - 06:50 PM
& can I ask how much the body-roller was?
I've seen that spit roast on ebay, think its about 90ish
Linky
GreaseMonkey is correct. It is the one on ebay that I bought. It cost £110 including postage and it arrvied falt-pack, so needs to be welded together. I decided to modify it a little to suit my needs but for the money it gives you a good starting point.
#108
Posted 24 August 2009 - 11:52 AM
Next on the list is to finish removing the Waxoyl and then tackle the seam welding of the new panels that I've fitted.
I'll take some more pictures over the next couple of days and upload them to show my progress.
Luke.
Edited by LukeH, 24 August 2009 - 11:53 AM.
#109
Posted 11 January 2010 - 10:30 AM
Edited by LukeH, 30 August 2020 - 07:39 PM.
#110
Posted 12 January 2010 - 11:22 PM
#111
Posted 13 January 2010 - 08:21 AM
Great project, love the carbon fibre binacle, the boot floor should be nice too. How did you get on with the remote bonnet catch? Is it up and running yet?
I had a prototype working but I'm thinking that I might just run an internal pull cable instead in order to keep things simpl and avoid problems later on. I might change my mind though which is often the case when you spend this much time restoring a car.
Luke.
#112
Posted 23 January 2010 - 09:14 PM
#113
Posted 05 February 2010 - 10:03 AM
#114
Posted 10 February 2010 - 03:48 PM
I spent a few hours last night working on my carbon fibre/fibreglass composite doors. The majority of the time was spent fabricating some spreader plates to allow the standard locks to be fitted. I will eventually bond these into place using Tiger Seal but for the time being I did a dry fit to make sure eveything lined up.
This is what the doors like (a bit dusty)
This is where I have cut out the holes for the locks.
Internal view of locks bolted into place with the spreader plates that I made.
The lock fitted.
Next job will be making some spreader plates so that I can bolt on the MK1 external hinges that I have just purchased. I will also be fabricating a panel to bond into the top to allow MK1 sliding windows to be fitted (when someone replies to my post in Body section about the size so that I can sut some Polycarbonate to size!)
Luke.
#115
Posted 24 February 2010 - 05:02 PM
Quick update - 05/02/2010
I have also rebuilt the rear end and I added a pair of MK1 light adapter brackets at the same time. I have replaced the boot hinge panel, the corners under the lights and the rear boot floor plus some repairs to other areas.
Thats all for now. Luke.
Nice job on the light conversion! Not an easy one to do!
#116
Posted 24 February 2010 - 05:36 PM
Thanks but to be honest it was a horrible job to do and not one that I would like to do again in a hurry! The conversion plates just did not seem to line up properly and they certainly weren't the correct shape.
If I'm honest, I'm not a 100% happy with them and I have even thought about cutting them out and doing them again, but the lights seem to line up ok so not worth it.
Luke.
Edited by LukeH, 24 February 2010 - 05:37 PM.
#117
Posted 01 March 2010 - 11:21 AM
Anyway, I have mainly been working on the carbon doors which has included me converting them from MK3 windows to MK1. This has involved me making a blanking channel out of plastic, which was then bonded to the doors using Tiger Seal (the white bit in the picture). Next on the list was some polycarbonate sheet that I have bought from a local supplier to cut out my own MK1 windows. You can buy these already cut but they seem to cost a fortune so I thought I'd make my own.
Window channel
Polycarbonate sheet;
I have also made some panels out of 2mm aluminium to carry the original lock/handle mechanisms but with a slight twist of having remote central locking. I have made a bracket to allow the remote unit to attach directly to the lock mechanism the only trade-off is that I won’t be able to lock the doors from the inside without pressing the remote but I’m not too worried about that. I have tested the operation of the locks and they work perfectly.
The total weight of the doors so far is 8KG and I imagine with the poly windows and catches fitted, they will be about 10KG each compared to the original 35-40KG each of the old doors.
The final thing I have made is some brackets to carry the strain/weight of the MK1 external hinges that I will be fitting. I have made them so that they bolt to the original internal hinge holes and then the MK1 hinges will bolt to them.
That’s all for now.
Luke.
Edited by LukeH, 01 March 2010 - 11:23 AM.
#118
Posted 08 March 2010 - 11:01 PM
I also replaced the bolts on the MK1 rear light I purchased at Bingley Hall as the originals were shot and needed drilling out.
#119
Posted 08 March 2010 - 11:10 PM
#120
Posted 11 March 2010 - 04:42 PM
