Been scratching my head the last few days about the exact routing for the various underbody pipes and cables on my '68 Cooper. Some of it is fairly obvious, but I can't find any pictures of what it really should look like. Any help with the routing of the hydrolastic pipes, brake pipe (single line), fuel pipe and battery cable would be fantastic!
Chris
Routing Of Underbody Pipes (hydrolastic, Brake, Fuel, Battery Cable)
cgbrowne
, Dec 04 2007 03:54 PM
5 replies to this topic
Posted 04 December 2007 - 03:54 PM
Posted 04 December 2007 - 04:06 PM
dklawson is very knowledgeable on early cars try a PM to him
Posted 04 December 2007 - 06:35 PM
Hi..!..hydro pipes travel down inside clips, battery cable travels down tunnel edge in long c clip, brake line travels down R/H side outter clips and fuel line travels down L/H side outter clips, sorry but can not find photo of under neath my mini...
Posted 04 December 2007 - 08:03 PM
Thanks for the info! Here's a picture of where I'm up to so far.
[attachment=45012:IMG_1212.jpg]
Centre clip
[attachment=45011:IMG_1214.jpg]
Front clip
On the front clip, does the hydro pipe clip sit behind the wider (more flexible) part of the clip, or the inner (more rigid) clip?
My recollection tells me its the latter, but I'm just not sure! ... And if that's the case, where does the brake line go on the front clip?
Thanks!
Chris
Centre clip
Front clip
Thanks!
Chris
Posted 04 December 2007 - 10:24 PM
when you are ready for final fit purchase a couple of mts clear plastic tube dia big enough for hidro pipe cut it @ 100mm and slit it and put around hidro pipe where clips are to stop pipe vibrating and chaffing through pipe, do same with fuel and brake lines..................
Edited by mk1leg, 04 December 2007 - 10:25 PM.
Posted 05 December 2007 - 01:12 PM
Thanks! That's a top tip. I know that there was something similar originally, but these have long since disappeared!
Chris
Chris
