Fitting Rear Screen
11 replies to this topic
#1 GraemeC
GraemeC
  • 7,440 posts
Posted 05 December 2007 - 02:46 PM
OK, I have my thoughts on the best way, but lets see everyone else's.
When installing a rear screen (or I suppose a front for that matter) do you:
Place rubber onto car, fit corner of screen into rubber and the use a suitable tool to ease the screen in all the way round.
or
Fit rubber to screen and then use the 'string technique' to fit to the car.
Edited by GraemeC, 05 December 2007 - 02:59 PM.
#2 Ethel
  • 26,088 posts
Posted 05 December 2007 - 02:52 PM
First method, allows you to silicone the seal and that's how it's designed if you look at what the filler strip does.
#3 bert998
bert998
  • 2,558 posts
Posted 05 December 2007 - 03:19 PM
Agree with Ethel. I only use the string method on the fixed rear quarters.
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 05 December 2007 - 04:35 PM
warm the rubber in some hot water helps as well
#5 Jammy
Jammy
  • 25,397 posts
Posted 05 December 2007 - 06:31 PM
Just DON'T use soap or washing up liquid!!
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 05 December 2007 - 06:46 PM
or tyre leaver
#7 bert998
bert998
  • 2,558 posts
Posted 05 December 2007 - 06:47 PM
Or just your fingers :thumbsup:
#8 GraemeC
GraemeC
  • 7,440 posts
Posted 05 December 2007 - 06:49 PM
Actually I intended to use a tyre leaver.
Admittedly a small, strong plastic one intended for a bike.
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 05 December 2007 - 07:29 PM
Front and rear.... see:
http://www.theminifo...showtopic=10693
In the FAQ section.
#10 midridge2
midridge2
  • 1,794 posts
Posted 05 December 2007 - 07:30 PM
minis front and rear screens use a claytonwright sp rubber, these are designed to be fitted to the shell first then the bottom of the screen dropped in and the rubber eased over the glass.
regards the filler strip many cars screen rubbers were the type that are fitted with cord and had a filler strip also, these were fitted before the glass was inserted in the car but with claytonwright are fitted after.
#11 GraemeC
GraemeC
  • 7,440 posts
Posted 05 December 2007 - 07:35 PM
Two excellent posts - I'll reprimand myself later for not having consulted the FAQ.
In my defence that is how I was planning to do it, just a discussion came up earlier today where someone recommended the rope trick. Midridge's info is nice background - thanks.
#12 M44K TS
M44K TS
  • 3,104 posts
Posted 05 December 2007 - 11:27 PM
oooooh, i needed to ask this too.
Cheers :)
