Rose Joints
Posted 15 March 2005 - 10:27 PM
Posted 16 March 2005 - 07:27 AM
Posted 16 March 2005 - 10:22 AM
Posted 16 March 2005 - 10:38 AM
They have a very common habbit of rusting themselves to the arm. The only way I've found to remove them is to put the arm in a vice, and heat the end where the bushes were until the outer is red hot, you will see the sleeve heat first, allow to cool slightly and with mole grips, woblle left and right, eventually they will loosen and can be withdrawn..
Posted 16 March 2005 - 12:38 PM
Rose joints will take all the compliant motion out of the suspension. (There are no elements left with any "give"). All those nice squishy rubber and hard plastic bits you're used to are gone. The suspension will feel very precise. It will also transfer every bump and shock into the car. As mentioned, they really aren't for a street car.
Posted 16 March 2005 - 01:52 PM
Posted 16 March 2005 - 05:26 PM
Posted 16 March 2005 - 08:05 PM
http://basic1.easily...mbottomarms.htm
MiniMoi
Posted 17 March 2005 - 12:12 AM
For those who have never seen a rose joint or other spherical bearing, imagine a steel ball, now machine two equally sized flats at two parallel spots across the diameter of the sphere. Drill a hole through it, right on center, from one flat to the other. Now take the ball and put it inside a short hollow cylinder. Squish the cylinder down until it buckles, trapping the ball inside. That's your rose joint.
When they wear, you have a ball floating around loose in a bigger spherical cavity. They literally are made by swaging the outer race to the ball and them machining the deformed outer ring. There's no way to adjust the play out once they're worn. The only acception I've seen to this is a spherical bearing product called a Lufa bearing where the ball is removable and replaceable.
Posted 17 March 2005 - 10:14 AM
minispares sell seals for £7 each
Posted 17 March 2005 - 12:13 PM
Posted 17 March 2005 - 03:06 PM
Posted 17 March 2005 - 03:51 PM
Posted 17 March 2005 - 04:16 PM
Posted 17 March 2005 - 05:07 PM
