Removing Blobs.
4 replies to this topic
#1 Big_Adam
Big_Adam
  • 7,435 posts
Posted 12 December 2007 - 01:49 PM
Yo,
My spray gun leaked on the car. Got five or so blobs of paint. Do I wait for them to dry then ..... what?
Cheers for any advice.
#2 jack_marshall
jack_marshall
  • 2,540 posts
Posted 12 December 2007 - 06:27 PM
What were you painting?
Metallic or solid?
If its solid they will flat out with a rubbing block and able to polish back.
If its metallic and its the basecoat, then it needs flatting and another coat or 2 before laquering.
If its metallic and its the laquer, chances are they will flat out with a rubbing block and polish back.
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 12 December 2007 - 08:03 PM
Primer, so block sander thing.
Where do I get one of them? Or is it just a block with some wet dry?
#4 blue redtop
blue redtop
  • 1,605 posts
Posted 12 December 2007 - 08:19 PM
flat block of wood will do the trick.
go for 800 grade as its only primer :shifty:
#5 jack_marshall
jack_marshall
  • 2,540 posts
Posted 12 December 2007 - 11:06 PM
Ahh, primer.
Block of wood works, but if your doing alot of flatting.. like the whole car, spend a couple of 10er's and buy a couple rubbing blocks from a paint supplier.
Well worth it.
I use 320 to flat primer for solid colours and 1200 for metallics. But thats me. Others will suggest finer for both.
