Oil Leak When Parked Up 998cc
Posted 17 December 2007 - 06:36 PM
Posted 17 December 2007 - 06:41 PM
Hello people wondering if anyone cud help me i have a studio 2 998 and leaks oil all over the drive when parked up sumbody said to me it was a gear selector seal r sumfing? does anyone know what this cud be and what the proper name for it is and were to get it cheers.
they'll be referring to the gear change selector seal
where the shaft enters the gearbox from the gearstick, common problem on most mini's (including mine) you can buy a repair kit from minispares, comes with new seal, gaitor and bush. about £5
link
not too hard to fit, although you need to disconnect the linkage, which requires drifting out a roll pin that can be extremely seized if you're unlucky, but if its leaking oil, it might not be a problem as it will be well lubricated
Haynes will tell you how to do it, jack the car up, put it in reverse, you'll see the pin (one closest to the gearbox) just drift it out with a suitable tool, i use one of those precision screwdrivers, as the screwdriver bit fits inside the roll pin, and the body of the driver is the same as the pin itself, so it lines itself up perfectly. then tap it with a hammer until it is out. then just remove the linkage and change the seal
don't forget to put the new dust cover back on before you re attach everything
Edited by Monstrous, 17 December 2007 - 06:44 PM.
Posted 17 December 2007 - 06:43 PM
next park you mini over a big bit of cardboard and go into your house for the night
next morning go out side and see where the oil has leaked from, by looking at the card and drips from the engine
the usual place is the gear selector rod (the bit between the gear stick and the engine) its at the back
Posted 17 December 2007 - 06:45 PM
Posted 17 December 2007 - 07:00 PM
Posted 19 December 2007 - 06:11 PM
