Ive got a whistleing noise coming from my car since engine change its not the alternator belt i think its air getting in somewhere anyone experienced this before?
Whistling Noise
david_godfrey
, Dec 23 2007 12:11 PM
4 replies to this topic
Posted 23 December 2007 - 12:11 PM
Posted 23 December 2007 - 12:13 PM
do the pitch of the whistle change with engine speed or road speed ?
Posted 23 December 2007 - 12:19 PM
Spray some WD40 where the carb joins the inlet manifold. A leak there will cause a whistling sound, and WD40 should cause the engine note to change. You may just need to tighten up the carb, or there may be a bad seal caused by an uneven mating surface, or part of the carb fowling something preventing it from mating properly.
Posted 23 December 2007 - 12:29 PM
Whistling?
Could you be more specific...
Is it a Weeeeeeeeep or more of a Psssssssssht?
Only problem with the wubble-u-dee fortee trick is you'll have contaminated the dodgy mating surfaces in finding them
Edited by Ethel, 23 December 2007 - 01:47 PM.
Posted 23 December 2007 - 01:46 PM
You fit a K&N cone filter?
