Plugs
9 replies to this topic
#1 robson
robson
  • 798 posts
Posted 25 December 2007 - 03:17 PM
Afternoon all and seasons greetings :D
I understand that one should goto a colder spark plug if the current ones are running too hot, but how do i tell if it is too hot? Surely it cant be as simple as just the temperature that the engine runs at? Which is affected by the cooling system!
Mine has a 4 core rad, no heater matrix, is a 1380 and runs always below the white temperature marker, which suggests the engine itself is cool enough, if indeed the spark plug temperature is in relation to the engine temperature
Is it just trial and error? Should i get some 7's? Currently using 6's
#2 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 25 December 2007 - 03:25 PM
This is a bit of a debate really,... plenty of people here Use the NGK BPE7's,... but plenty of people use the BPE6's too.
if there's nothing going wrong,... there's no real reason to swap anything, but you could always try some 7's in there anyway and see if it does anything.
If it aint broke, it probably doesn't need fixing :D
Edited by Retro_10s, 25 December 2007 - 03:26 PM.
#3 robson
robson
  • 798 posts
Posted 25 December 2007 - 03:46 PM
a good motto, if only i could stick to it :D
ill try some 7's, they are cheap anyway!
#4 sixwheeler
sixwheeler
  • 500 posts
Posted 25 December 2007 - 06:46 PM
All else being equal, you tell by having a look at the plug once it has run for a while.
See here...
#5 mineeeeee
mineeeeee
  • 117 posts
  • Local Club: me and my mini
Posted 25 December 2007 - 07:06 PM
Have you got a problem with your plugs?
The way i read the post your looking for a cure to a problem you dont have
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 December 2007 - 11:06 AM
The only real way to tell if the temperature is exactly right is with an engine ocilloscope on the rollers. The waveform will show if the plugs are running properly, if there is a serious problem however it will show as burned plugs or running on. If they are slightly out of range you won't really be able to tell and it won't hurt performance much.
#7 Big_Adam
Big_Adam
  • 7,435 posts
Posted 26 December 2007 - 11:08 AM
I got an ocilloscope if anyone need it.
:P
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 December 2007 - 11:15 AM
An electronics one or an engine one fitted to a diagnostic tuning machine and a set of rollers?
#9 robson
robson
  • 798 posts
Posted 26 December 2007 - 08:00 PM
guessing the usual electronics one :D
You are sort of right, there is no problem per se, but if i could be using more suited ones, i will :wub:
Plugs seem fine, tips are slightly brown in colour and the ring around the base is the usual black, but not severely so. Would suggest running slightly too lean, or possibly running too hot. Wouldnt be by much though. All of the plugs are like this and they are a year old. Just fitted a new set of 6's, might try some 7's ill see how these look after a while.
If say i required a non existing 6.5 plug, would it be better to use 6 or 7? what long term issues could appear? Thanks
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 December 2007 - 11:30 PM
Don't look so closely at plug colour, it's only a good guide to the health of an engine if you are using leaded fuel. Those detailed colour charts they put in Haynes don't work for unleaded. If the tip's brown it's probably OK. That's about as far as you can tell with unleaded. If the plug ceramic isn't cracking up and scorching and the tip isn't burning again it's probably OK. One more reason that now more than even it takes either a lot of experience or proper equipment to really go into detailed tuning.
