Spraying Zinc 182 Anti Rust Primer?
5 replies to this topic
#1 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 26 December 2007 - 12:13 PM
Is it possible to spray Zinc 182 Anti Rust Primer? If so how? would i just do something like 3:1 with thinners? If so what type of thinners?
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 26 December 2007 - 01:00 PM
i use the spray zinc primer straight from the spray can's you can buy it in
#3 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 26 December 2007 - 01:04 PM
It seems a bit thick to spray straight out the cans..
#4 dave20046
dave20046
  • 672 posts
Posted 26 December 2007 - 05:15 PM
could you not do regular primer->zinc primer another coat of regular primer and then your base and final coat?
#5 jack_marshall
jack_marshall
  • 2,540 posts
Posted 26 December 2007 - 10:12 PM
Not sure what Zinc 182 primer is based on but try thinning it with cellulose thinner till it runs off a mixing stick rather than drips off.
Dont make it too thin, like water.
The try test priming something.
If it works out well, then bingo.
Although, I wouldnt zinc prime a whole car to be honest, theres no need.
#6 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 26 December 2007 - 10:17 PM
Cheers >_< nah im not zinc prime in the whole car, the car was sprayed a while back, however it removing all the sound deading off the floors, so as i already have a tin of zinc primer i thought i might aswell use that on the floor...
Thanks for the help :D
