It is a verto clutch.
Posted 21 March 2005 - 01:01 PM
Posted 21 March 2005 - 03:04 PM
Edited by GuessWorks, 21 March 2005 - 03:04 PM.
Posted 21 March 2005 - 03:46 PM
Posted 22 March 2005 - 12:00 AM
Posted 22 March 2005 - 09:37 AM
Posted 22 March 2005 - 03:13 PM
Posted 21 May 2017 - 01:33 PM
Excellent description Ta
I asked someone if they had a flywheel puller and they replied "what size", I think I will buy one anyway so what size is it or are they universal + what is a breaker bar
Posted 21 May 2017 - 03:38 PM
Many of the so-called Mini flywheel pullers are flimsy junk that will usually fail. Look for one that is just a nice, thick piece of plate (maybe 3/4" thick) with a large central bolt with a very fine thread, and a set of 3 high tensile bolts, ideally grade 10.9. I had an anonymous one years ago that answered that description, and worked well. There is also a vital bit that fits into the end of the crankshaft and provides something for the main bolt to push against. Omit that at your peril, as some people have had the puller bolt jam into the end of the crankshaft. The plate was painted green and had been cut out with a flame cutter of some type. It was far from being expensive, way back in about 1976. Some of the lightweight modern ones are made from nicely finished but flimsy castings. The old one was unbelievably crude and utterly reliable. No money spent on making it look pretty.
I think that my fine old tool has been lost or stolen, but I will make one like it when needed. I will try to find a large UNEF bolt (finest thread pitch commonly available, for more force with less torque) and get a suitable tap.
The old puller was for a pre-verto clutch with UNF threads on the bolts, but when I had a later Mini with Verto clutch I redrilled the plate with a second set of holes at the appropriate centres and found that three bolts from the prop shaft donut coupling on a scrapped Opel Rekord D (worst car I have ever owned, albeit the ignition coil was better than any Lucas item) fitted perfectly. It worked rather well!
Posted 21 May 2017 - 04:01 PM
Posted 21 May 2017 - 04:29 PM
Posted 21 May 2017 - 04:31 PM
I butchered a 1/2" AF spanner for these, by heating it across the stem with an arc welder (all that I had at the time) and bending it by hammering, in the vice. The bead of extra metal that was inevitably added went on the inside of the bend, and despite the spanner being chrome vanadium and the welding rod being standard E6013, it was adequately strong and did not crack. Nowadays I would heat it with TIG and it would look far neater. Don't have, or want, a gas axe, and I doubt that a propane blowtorch would have done the job.
It is usually very difficult to get the last bolt in. It helps to put it in the cover before putting the cover in place. Some people just leave it out, usually without ill effect, but I can't say that the casting will not distort or fatigue under the load of an extremely highly tuned engine. Certainly ok on a standard 998, driven hard for at least 100k miles, in my direct experience.
Jacking the engine and heaving it about as far as various bits allow does gain you some finger room.
We all had to do this at one stage, as Mini beginners. Have fun!
Edit: Sorry, this was about the cover bolts as mentioned by blacktulip. Boycie posted about his puller just as I was finishing my comment.
Edited by tiger99, 21 May 2017 - 04:32 PM.
