Pipe On Carb To Block Or Not To Block
11 replies to this topic
#1 ace
ace
  • 140 posts
  • Local Club: Posh Mini Owners Club
Posted 31 December 2007 - 02:06 PM
o.k quick one - is this correct - I have two k and n breathers on my oil crankcase breathers - so thats sorted - so on the carb should I block the CRANKCASE BREATHER PIPE CONNECTION - if so WHY and WHAT to block with ?!?!?!
pic attached to explain the below
1 - FUEL INLET PORT
2 - FLOAT CHAMBER OVERFLOW/BREATER
3 - CRANKCASE BREATHER PIPE CONNECTION
4 - FUEL MIXTURE ADJUSTMENT
thanks all
Ross
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 31 December 2007 - 02:14 PM
block
if you don't block the pipe on the carb it will suck air in through it and weaken your mixture
#3 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 31 December 2007 - 02:18 PM
we went through a very similar question here just the other day.
the general opinion was to connect it up in the "proper way that it was designed to work"
#4 Ethel
  • 26,137 posts
Posted 31 December 2007 - 02:20 PM
Yes you must, but in a minute someone will be along to tell you to get attached back to the crankcase breathers. :thumbsup:
A short length of hose with a bit of rod or a suitably sized bolt stuck in the end will do. If you don't block it you'll have a bad air leak which will ruin your idle and possibly allow dirt in to ruin the engine as well.
#5 ace
ace
  • 140 posts
Posted 31 December 2007 - 02:25 PM
just read all the posts - as I have brought 2 k and N breather filters I think I will put them on and block the pipe on the carb - Any suggestions what to block with!!!
thanks
Ross
#6 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 31 December 2007 - 02:28 PM
#7 ace
ace
  • 140 posts
Posted 31 December 2007 - 02:30 PM
Yes you must, but in a minute someone will be along to tell you to get attached back to the crankcase breathers. :D
that's why my idle might be a bit popopo (thats the sound it makes :thumbsup: )
will do it tonight!!
#8 stardude
stardude
  • 2,457 posts
  • Local Club: hilltop mini's
Posted 31 December 2007 - 05:28 PM
some people use a bolt in a bit of pipe, with one of those metal hose clamps aswell
#9 imabitnaughtyxx
imabitnaughtyxx
  • 4,619 posts
Posted 31 December 2007 - 05:33 PM
just a quick hijack, you know the fuel breather (do not block) i have a length of vac hose on this but nothing on the end its just, open ended. should i put something on the end like a filter or will it be ok
PS in the original metro the original pipe went into the servo i think, but i dont have one on my mini
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 31 December 2007 - 06:11 PM
The breather hosing and vacuum servo hosing are different and seperate systems, they should not be connected together.
Vacuum hose may proove to not be fuel resistant and may break down, it also is fairly narrow bore if you're using what I'm thinking of and won't allow fuel to flow as fast as it should if any wants to escape from the float chamber. Essentially this will be the same as blocking it up and will prevent the overflow from functioning, flooding the jet if there is a problem with the float. What is original is a length of steel fuel line running around the outside of the clutch cover from the carb down to the bottom of the gearbox and terminating at subframe level pointing into the road. It is connected to the overflow by a short fuel hose. You shold aim for something like that using copper. It doesn't need to end in anything special, it's just an overflow and in theory will never be used. If you use plastic or rubber for the whole length you will need to protect it from the heat of the exhaust so you may as well use a metal section.
#11 cowboy
cowboy
    Friend of TMF
  • 2,799 posts
Posted 31 December 2007 - 06:25 PM
just a quick hijack, you know the fuel breather (do not block) i have a length of vac hose on this but nothing on the end its just, open ended. should i put something on the end like a filter or will it be ok ( yes this will be OK)
#12 imabitnaughtyxx
imabitnaughtyxx
  • 4,619 posts
Posted 31 December 2007 - 06:33 PM
hmm as i said though i dont actually have a servo on the mini so theres nothing coming off the fuel breather anyway. I have used 180 degree temp silicone vacuum hosing on the crankbreather pipes as well, this was recommened to me by a forum member, are you telling me this cannot be used for the breather system at all? im confused
