How Much Can I Skim My Head By?
Posted 02 January 2008 - 07:15 PM
Posted 02 January 2008 - 07:18 PM
Posted 02 January 2008 - 07:23 PM
Posted 02 January 2008 - 07:29 PM
The problem would be making the head face too thin to hold a gasket. By the time the valves reach full lift the piston will be well out of the way - assuming the timing chain never snaps. Cylinder heads are sand cast so no 2 will ever be the same to give a definitive answer.
Do you mean there won't be enough threads on the head bolts to compress the gasket?
Edited by adam25, 02 January 2008 - 07:29 PM.
Posted 02 January 2008 - 07:37 PM
A cylinder head is largely hollow due to the cooling water passages. Make the bottom face too thin and it can flex: Imagine bolting a strip of sheet metal on to a flat surface by each end compared to using a chunky bit of bar.
Posted 02 January 2008 - 07:40 PM
Posted 02 January 2008 - 07:48 PM
Posted 02 January 2008 - 08:17 PM
Posted 02 January 2008 - 08:37 PM
Measure down the oil hole, then mesure the thickness of the head.
Take the head thickness and take away oil hole depth.
THAT figure is the amount left on the head, if you remove this amount you WILL bust into the oil way on the bottom of the head.
So leave like 1-2mm and you're fine.
Besides, you need to work on ratio, not just lumping off amounts. Too high and the car will run funny.
Posted 02 January 2008 - 09:15 PM
Depth of a standard cylinder head is 69.9mm approxDoes anyone know the measurement for a standard mini head from the headgasket face to the rocker cover face so i know whether the ones i have have been skimmed or not?
