Hammerite In Paint Brushes
24 replies to this topic
#1 Mininman_Aid
Mininman_Aid
  • 158 posts
Posted 03 January 2008 - 02:42 PM
Hi guys
Can anyone tell me how to get hammerite out of paint brushes??
I've tried many things, including the hammerite thinners and detergents and all kinds of stuff, but hammerite behaves different to any other paint and seems to bind itself to my brushes!!
Any advice would be appreciated!
Aid
#2 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 03 January 2008 - 02:52 PM
I've always used celly thinners.
But if they're cheap brushes,.. the thinners will eat them :D
Usually i jut buy some cheapo 99p brush sets and use them and bin them.
#3 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 03 January 2008 - 03:08 PM
Thats what I do
:D
#4 Mininman_Aid
Mininman_Aid
  • 158 posts
Posted 03 January 2008 - 03:11 PM
Thats what I do
:D
Ha ha, i've done similar up till now, but i was hoping i could make on last a couple of days...
ah well i'll just keep using the cheap chuck away brushes!
#5 minimender
minimender
  • 1,589 posts
Posted 03 January 2008 - 03:27 PM
Thats what I do
:D
Acetone will clean them but it soaks into your skin if you get it on your hands. Melts hammerite though.
#6 Mininman_Aid
Mininman_Aid
  • 158 posts
Posted 03 January 2008 - 03:29 PM
well i've been using my dads brushes untill now, but they are starting to run out! So i guess i'll just stock up next time i see some cheapie ones!
#7 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 03 January 2008 - 03:37 PM
i used to wear rubber gloves (vinyl disposable ones) for hammeriting. when you have finished, dip the brush in the hamerite, hold the brush eng in the glove palm and take the glove off so its inside out around the brush and wrap round handle.
paint will still be wet next day when you take glove off and you can carry on.
#8 Mininman_Aid
Mininman_Aid
  • 158 posts
Posted 03 January 2008 - 03:41 PM
thats a good idea... I've got a brush sat in thinners waiting for me to use it tomorrow at the moment!
#9 schneill
schneill
  • 127 posts
  • Local Club: Tyred And Exhausted
Posted 03 January 2008 - 03:55 PM
I always use paint clogged brushes when i'm stripping paint with nitro mors. Eventually it gets rid of all the paint stuck in the brush. Might cause problems if you don't clean the nitro mors out though and then go back to painting with it.
Schneill
#10 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
Posted 03 January 2008 - 04:41 PM
If you want to use them the next day either wrap them in a plastic bag & put an elastic band around the handle... or get an old cup/beaker, fill it with white spirit and put the brush in there overnight. The next day just drain the brush best you can, mix it into the paint for a bit and carry on.
Soaking them in water will not work because hammerite is solvent/cellulose based...
But for what it's worth yeah just get some cheapo brushes next time :D
#11 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 03 January 2008 - 04:50 PM
i just use the cheap brush method
#12 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 03 January 2008 - 04:51 PM
silicone based... a right pain in the arse.
#13 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 03 January 2008 - 04:58 PM
your not ment to poke them up there to clean them
#14 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 03 January 2008 - 05:00 PM
Ooops, that's wher i've been going wrong!... wondered why my black hammerite is always russet brown :dontgetit:
#15 1984mini25
1984mini25
  • 8,785 posts
Posted 03 January 2008 - 05:02 PM
I’ve always left the brushes in white sprit and the next time i use them i rub the brush across a wire brush in one direction, which tends to loosen the old paint, removes the lose bristles.
