13" Alloys And Sportspack Arches, Problem?
Posted 03 January 2008 - 04:36 PM
Posted 03 January 2008 - 04:41 PM
Posted 03 January 2008 - 04:50 PM
Posted 03 January 2008 - 04:54 PM
Posted 03 January 2008 - 05:00 PM
Posted 03 January 2008 - 05:05 PM
10s...
Posted 03 January 2008 - 05:26 PM
Posted 03 January 2008 - 05:36 PM
Posted 03 January 2008 - 05:50 PM
Sorry for this stupid question, but you often hear people saying that they might get bigger wheels to feel out there arches, but from what i see, the wheels appear to fill (width ways not height) the arches, how come?
If you are refering to mine, it because those 10s have built in spacers in order to clear the 8.4" disc brakes. They are 10x5 whereas the Sportspack wheels are 13x6. Due to being spaced out the 10s stick out the same distance as the 13s. The 10s also have 165/70/R10 tyres which means that the overall height of the wheel is almost the same as the 13s (175/50/R13).
Then you just need to set the ride height correctly so they don't look overarched (the rear on mine now sits lower than that photo above).
Posted 03 January 2008 - 08:34 PM
S5030645.JPG 45.46K 11 downloads
S5030646.JPG 212.57K 7 downloads
S5030647.JPG 268.76K 8 downloads
Posted 06 January 2008 - 04:16 PM
Posted 06 January 2008 - 04:35 PM
Do you have to spacer them though?Hi. Just thought id share some info. I have got 12x6 with sportpack arches and they are great. you only have to chop away a tiny bit of the front of the outer wing as they do catch when on full lock.
Posted 06 January 2008 - 07:15 PM
NOOO! they make the problem worse as they push the wheels out and therefore cause the wheel to rub even more on the outer arch.
Posted 10 January 2008 - 02:24 PM
Posted 10 January 2008 - 02:29 PM
That's because they are 12", Sportspack wheels are 13" and so need more cutting to stop them from rubbing.
