Fuel Senders......
1 reply to this topic
#1 Renessy
Renessy
  • 306 posts
  • Local Club: minisevenclub Holland
Posted 04 January 2008 - 11:14 AM
As the topic title says. Which fuel senders did you use?
I found a couple of different fuel senders and wondered which one did you use? The are top mounted and side mounted senders..... There carbed or injected models....
Also the output range of the senders matters. In my case it has to be between 0 and 100 ohm, but that can be fixed....
Anyhow, any help wil be very appreciated!
René
#2 Alburglar
Alburglar
    Das Pingu's
  • 3,332 posts
Posted 19 January 2008 - 12:24 AM
see me project thread. all the info you need is on there. I used the standard smiths fuel sender and used resistors to get 0 - 100 ohms.
