Twin Carbs With Supercharger?
11 replies to this topic
#1 LukeH
LukeH
  • 1,004 posts
Posted 04 January 2008 - 01:10 PM
I was wondering whether it is possible to run twin carbs with a supercharged A series engine?
I've been looking at the Jonspeed kit in particular and notice that a singe HIF44 carb is used but it is possible to use twin carbs? If so, would it have any negative impact on setup/performance?
The reason for my question is that I will be soon fitting a 1275 with twin hs2's then eventually I will supercharge it, but perhaps retain the twin carbs.
Cheers, Luke.
#2 scars
scars
  • 197 posts
Posted 04 January 2008 - 01:31 PM
Cheers, Luke.
I'd be intereseted to know the answer to this too. With the Jonspeed kit their doesn't seem to be the room to fit them.
#3 Wil_h
Wil_h
  • 3,244 posts
Posted 04 January 2008 - 02:06 PM
I think that the ultimate limiting factor is space.
The HIF44 will flow enough in a turbocharged mini for 250 to 300 bhp, so fitting twins seems like an awlful lot of effort for nowt.
#4 LukeH
LukeH
  • 1,004 posts
Posted 04 January 2008 - 02:51 PM
Space issues would make sense. The only reason i wanted to know really is that I quite like the look of twin carbs that and the fact that i've just bought some!
Thanks for the reply, Luke.
#5 Ethel
  • 26,088 posts
Posted 04 January 2008 - 03:09 PM
Would surely be a nightmare to set up - how would you balance blow through carbs and what would be the point of 2 suck through carbs on one blower inlet?
#6 LukeH
LukeH
  • 1,004 posts
Posted 04 January 2008 - 09:02 PM
There probably wouldn't be much point. I merely wondered if it was possible, mainly due to aesthetics than anything else.
#7 stardude
stardude
  • 2,457 posts
  • Local Club: hilltop mini's
Posted 04 January 2008 - 09:05 PM
just stick a weber on the supercharger :D
#8 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 13 January 2008 - 12:14 PM
i would like to see a 300bhp a series i thought the max was about 220bhp and don't last for long. you can use twin carbs but better for suck through and would require a lot of fabrication Weber would be the easier way out or for same power but better fuel economy you could adapt a pair of bike carbs these are brilliant items
#9 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 13 January 2008 - 01:39 PM
the mini williams is a well known over 220 bhp a-series powered mini
#10 In-a-mini
In-a-mini
  • 831 posts
Posted 13 January 2008 - 03:03 PM
yeah well known but not much over 220bhp and regulaly rebuilt spoke to mat a few years back he used to come down to southend it is a well sorted car
#11 mini93
mini93
  • 8,615 posts
Posted 13 January 2008 - 03:12 PM
hes got more than that now by the way, or has been said hes yet to conferm it as such
#12 mini13
mini13
  • 3,811 posts
Posted 13 January 2008 - 05:22 PM
I think will is refering to either the airflow that the turbo carb will give or possibly to it use on maestro turbo's which i think have put out close to 300hp.
but as said putting a webber on would be good, and certainly easier to set up than twin SU's
