How To Make A Trigger Wheel For Mapped Ignition
13 replies to this topic
#1 Udo
Udo
  • 1,670 posts
Posted 09 January 2008 - 08:16 PM
Someone asked for info on how I made the trigger wheel I sold recently so here goes.....
Take one Ford Sierra bottom Pulley
Remove the trigger part using heat on the trigger ring and some tyre levers
Trigger wheel laid on to mini 1275 bottom pulley
I fitted it separate to the damper by the following method (excuse the low quality paint drawings) its like a top hat with th top fitting into the damper recess
I got a mate to lazer cut out the following parts from 5mm steel plate
so I ended up with a disc with 5/8 hole in the middle and a ring
then assemble (sorry no photo) trigger ring with lazer cut ring inside then a piece of tube 65mm outside diameter with the disc on top
welded up then run up on a lathe just to tru it all up and painted
picture also shows longer crank bolt from minispares (note the allen key size is 1/2" imperial so not your usuall ones in your toolbox)
Finished item
welding could have been better but I personally ran it up to just over 6000rpm with no problems. If making again I would make the tube part slightly shorter as it was a little long and required the engine mount and lower rad bracket adjusting slightly
And questions just ask
Ian
Edited by Udo, 09 January 2008 - 08:20 PM.
#2 Sutty01
Sutty01
  • 603 posts
Posted 11 January 2008 - 01:05 PM
this is of great interest to me im just a little unsure what you mean , with no pictures could you elaborate please ?
also how does the special components and the kad kit differ ?
#3 Ethel
  • 25,971 posts
Posted 11 January 2008 - 02:07 PM
There are piccies, alas Udo's wheel involves some machining so not as home made as I hoped it might be. It is essentially the same as the other wheels you mention if not as pretty. I used a trigger wheels wheel on a turned down crank pulley http://www.theminifo...amp;hl=megajolt
#4 Sutty01
Sutty01
  • 603 posts
Posted 11 January 2008 - 02:12 PM
so whats wrong with the premaid ones as id rather buy pre made. ?
i say this cause i was told the trigger wheel isnt right for the mini , is this true ?
#5 Ethel
  • 25,971 posts
Posted 11 January 2008 - 02:21 PM
Nothing wrong with them at all - just the cost!
Any 36-1 wheel will work, I've seen web articles ranging from diy folded sheet steel to the SC style bolt on. Each may have its merits but they all do essentially the same job.
#6 01smartc
01smartc
  • 1,412 posts
Posted 11 January 2008 - 04:20 PM
Hi all, i had my normal mini pully machined to have notches in it...The pics not very good but you get the idea!
Works really well and looks the dogs!
P.s If anyone really interested i can get a betta photo!
Edited by 01smartc, 11 January 2008 - 04:21 PM.
#7 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 January 2008 - 04:57 PM
Where did you get that done? did it cost you much?
#8 Sutty01
Sutty01
  • 603 posts
Posted 11 January 2008 - 06:00 PM
as above and anyone have a picture if the standard mini wheel
also
kad or special components ? if you had the choise, pro's con's anyone ?
#9 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 11 January 2008 - 06:01 PM
i got mine from specialist components. its great
#10 Udo
Udo
  • 1,670 posts
Posted 11 January 2008 - 06:19 PM
I didn't have to run it up on a lathe but while I was at it I thought i might as well, was fairly straight anyway as clamped it when welding and didn't try and weld it all at once and so get it too hot so you could do it without the lathe
This cost me very little when compared to the cost of the SC or KAD ones which was the reason for making it
£10 for sierra wheel
favour off mate for lazer cut bits but could be hand cut
£20 for welding which included the sensor bracket
#11 01smartc
01smartc
  • 1,412 posts
Posted 11 January 2008 - 08:27 PM
I had it done by a mate.. cost me a round of beers! lol
#12 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 11 January 2008 - 08:33 PM
Do you think he would consider making up another one? lol
#13 Sutty01
Sutty01
  • 603 posts
Posted 11 January 2008 - 11:15 PM
i just hope this solves my lumpy running
#14 Udo
Udo
  • 1,670 posts
Posted 12 January 2008 - 08:51 AM
No, mate moved to Holyhead island to work for a race team or something so dont have access to lazer cut bits anymore and i'm not cutting them by hand
