I was putting my wheel on the driver front side and one of the wheel nuts snapped off with the thread still in it would it be ok to drive with 3 nuts on? and also how do i go about fixng this please any help would be great
Wheel Nut Snapped Off With Thread?
hughes0
, Jan 10 2008 06:42 PM
2 replies to this topic
Posted 10 January 2008 - 06:42 PM
Posted 10 January 2008 - 06:47 PM
Emmm, got 4 bolts for a reason mate.
You got a 998 so I'm assuming drums all round.
If you're on 10inch no spacer wheel then you can bash the old stud out the back of the flange (take wheel off, take drum off, hit old stud out using a punch). If you're on bit when then you might have to take the flange off as the back of the brake setup will get in the way.
New stud/nut avalibe from mini spares.
Posted 10 January 2008 - 06:48 PM
You'll need to remove the hub and flange, knock the busted stud out of the flange and fit a new one.
3 nuts isn't advisable but you'll get away with it if you limit your journeys and take it easy untill its fixed.
Edited by roofless, 10 January 2008 - 06:49 PM.
