Clarke Engine Stand
4 replies to this topic
#1 TJenkos
TJenkos
  • 4,815 posts
Posted 12 January 2008 - 03:16 PM
Bought a clarke CES500A engine stand today but I cant see how it is meant to fix to the engine. I have 4 arms coming from the stand, which I believe you bolt to the engine block.
Has anyone done this before? Do I need to make myself an engine mounting plate?
Ta!
#2 icklemini
icklemini
  • 2,982 posts
Posted 12 January 2008 - 04:14 PM
yeah - the stand needs adapting so that the A series block bolts onto it sideways.
Use a drill to make the necessary holes in the clark adapter and bolt it onto where the oil filter housing goes...
#3 Udo
Udo
  • 1,670 posts
Posted 12 January 2008 - 04:17 PM
Most people drill a couple of holes in the back plate the arms are attached to and mount the block to it by either the mech fuel pump holes the alternator mounting bracket mounting holes or the oil filter holes
#4 TJenkos
TJenkos
  • 4,815 posts
Posted 12 January 2008 - 06:06 PM
Ah that makes sense, thanks guys!
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 12 January 2008 - 06:15 PM
Aye, I mounted mine via the fuel pump fittings.
Takes two 5/16th UNC on fuel pump UNF on alt.
