Suspecting that I have a stepper motor issue, I removed the stepper and checked the resistance from the common pin (Pin2) to each other pin (Pins 1, 3, 4, & 6). Resistance was ~15 Ohms to each pin. I then powered each pin w/ 12 VDC - the maximum rotation I achieved from any pin was probably 1/4 rotation at maximum. Shouldn't the stepper rotate multiple times? How is that achieved?
Note, the pin out I used is from the Rover MEMS Chapter 14:
3 2 1
6 _ 4
Can someone direct me on how to confirm whether I have a fried stepper or if my problem is on the wiring harness end? The solder connections that Sprocket mentions in the Pinned info on Stepper Motors "look" okay but I may need to check them differently. Advice?
Engine Harness Measurements
Before pulling the stepper motor, I also measured the signals going to the stepper (with the stepper connector disconnected). These measurements are on the engine harness connector going to the stepper motor:
Pin 2 to Pin 1: Nominal Battery Voltage Always Present
Pin 2 to Pin 3: ~10 VDC seen briefly during key off
Pin 2 to Pin 6: Nominal Battery Voltage Always Present
Pin 2 to Pin 5: Nothing detected during key on or key off
Pin 2 to Pin 4: 300mV measured consistently during key on
Pin out is the reverse of the stepper motor:
1 2 3
4 _ 6
Anyone know if this is correct? When I disconnected either connector at the Relay Pack, the voltage at Pin 2 dropped and did not come back up until I key on again. Is the voltage persisting on certain pins because it is still trying to move to a known position?
Would GREATLY appreciate advice at this point? Trying to have the car back together to drive by Monday.
Thanks!
Edited by Avl_Paul, 13 January 2008 - 01:52 AM.
