I rebuilt them because I was having problems getting the carb that has the open piston to draw enough air at idle speed compared with the other and the idle was erratic. I think one of the manifold gaskets was a bit suspect - blackened right through - so thought I had an air leak there, but now I think this is going to be a problem for me.
Soooooooo........what's the solution?
If it's not an easy fix is there anyone near Manchester with a spare carb and manifold I can borrow until these can be sorted out? NEED to MOT to get to Bingley!!!
Cheers!
