Draper Compressor And Spray Gun Kit
14 replies to this topic
#1 Rhys
Rhys
  • 898 posts
Posted 15 January 2008 - 03:30 PM
I'm looking at doing a home spray and i have seen a compressor and spray gun kit that i like the look of, im assuming that the fact it is a kit it will work OK, will cellulose paint be alright? Also is it a worth while purchase or a waste of money??
Compressor kit
Another i just found
Rhys
Edited by Rhys, 15 January 2008 - 03:45 PM.
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 15 January 2008 - 03:32 PM
if you want any quality of finish then you'll need a compressor with a 50ltr resevoir (preferably bigger)
#3 Rhys
Rhys
  • 898 posts
Posted 15 January 2008 - 03:39 PM
Sorry i forgot to post the link, its in the first post now, but from what you say its a load of rubbish as its a tiny little thing.
Rhys
#4 duncancallum
duncancallum
  • 533 posts
Posted 15 January 2008 - 05:26 PM
ive done a car with a 25ltr one panel by panel and then polishing it up.
its doable but not ideal
you want a compressor that will run a gun for without the presure changing otherwise your finish will go to *male chicken*
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 15 January 2008 - 06:53 PM
its ok for the money but as every thing you get what you pay for
#6 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 15 January 2008 - 07:12 PM
The second deal seems much better, but as Bumgle said, you get what you pay for.
#7 Rhys
Rhys
  • 898 posts
Posted 15 January 2008 - 07:20 PM
Well im more worried about the compressor i will buy a better gun as well, but do you not think that the compressor is any good, i want a complete respray obviously i want it to a fairly good standard.
Thanks for the help, it seems slow on here tonight doesn't it?
Rhys
Edited by Rhys, 15 January 2008 - 07:33 PM.
#8 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 15 January 2008 - 07:34 PM
If you want a respray to a pretty good standard, get a Devilbiss spray gun, and a compressor 2.5 hp or more. You can do it with lesser equipment, but it makes it harder.
#9 _Ad_
_Ad_
  • 482 posts
  • Local Club: Minis 'n' Oatcakes
Posted 15 January 2008 - 07:36 PM
Anything is possible lol!
I used a 25ltr compressor from Machine Mart (this ones very similar if not the same- http://www.machinema...th/airmaster-2) and a basic Clarke Professional syphon gun, about £150 worth of kit all together, with a tenners worth of gloss black cellulose and fully restored all the paintwork for my dads GS750 rebuild, the finish is brilliant.
I know the bike panels are only small areas to cover in comparison to car panels (saying that the GS tank is huuuuuge!!) but I had no issues with it having to continuously recharge etc, in fact I was able to give everything a good couple of coats without it kicking in, so I think it'd be fine for doing a panel or two at a time to be honest. Planning on completely doing my RSP with it this summer infact.
Obviously bigger is better, I've just got nowhere to physically store a bigger unit, and money was tight at the time so I went with the 25 litre and have no regrets in doing so, well worth it! :wub:
  • Attached File  1.jpg   78.19K   6 downloads
  • Attached File  2.jpg   75.85K   9 downloads
  • Attached File  3.jpg   55.2K   7 downloads
  • Attached File  4.jpg   64.23K   8 downloads
Edited by _Ad_, 15 January 2008 - 07:38 PM.
#10 Rhys
Rhys
  • 898 posts
Posted 15 January 2008 - 07:43 PM
Man that looks mint, good job I'm very impressed. Cheers for the tip, would you say the second one is any good then?
Rhys
#11 _Ad_
_Ad_
  • 482 posts
Posted 15 January 2008 - 08:07 PM
Cheers mate, I impressed meself haha!
Erm I've just noticed my link is wrong, mine is an Airmaster one, cost about £120 iirc, similar spec to the Tiger9/24 one on the Machine Mart website :wub:
About 2.5 horsepower mine is, and around the 8-8.5 cfm mark for displacement, so its slightly under what seems to be the spec most people recommend for spraying, but it did the job for me as shown in the pics of what I painted :wub:
Basically the main points to bear in mind-
The bigger the tank/reservior, the more air you have available in one go, meaning you can continuously spray for a longer period of time, which is necessary for massive panels so you don't end up with a patchy finish.
The bigger the air displacement means the bigger the airtool you can power as a basic example.
You don't really need to worry about things like max. pressure, because for spraying you'll only be outputting at between 40-60psi, which all compressors can do easily.
Don't take what I say as gospel :wub: I've just taught myself in the back garden on a piece of builders ply lol, so I've just picked stuff up along the way, hopefully this helps a bit tho.
Just go for the best you can afford mate! :wub:
#12 _Ad_
_Ad_
  • 482 posts
Posted 15 January 2008 - 08:09 PM
That Wolf one would be sound mate!
#13 Rhys
Rhys
  • 898 posts
Posted 15 January 2008 - 08:15 PM
Cheers, the second compressor i found looks good as i will use a DA sander and other tools too. I want a reasonable hobby compressor. Second problem is the spray gun, cheers Peter but the ones you have suggested are just a bit out of my range.
Rhys
#14 MNI11
MNI11
  • 25 posts
Posted 16 January 2008 - 04:56 PM
Rhys
Get one second? On Ebay?
#15 Rhys
Rhys
  • 898 posts
Posted 17 January 2008 - 02:23 PM
Ebay was a good idea, i had a look and they are still so expensive i like the look of the GTi's they do look quite good, but it looks like i may have to settle for less, im looking at around £100 anyone have any recommendations?
Rhys
