I've fitted a central locking kit to my Mini that was not specifically designed to be fit into a Mini. I have it working fine but I'm a little stuck on what to do with the parking lamp feature.
The central lock kit has the ability to flash the lights when it's locked/un-locked and it also has a car tracer feature that flashes the lights for 25 seconds to help find the car in a car park.
The diagram suggests that the wires from the control box should be connected to "Parking Lamps" should I connect these to the Mini side-light circuit or would it be possible to connect to the indicator/hazzard circuit. Whould I need to add in a realy if connecting to the indicator circuit?
This is the wiring diagram, it's not the best but as I say, I have the central locking working fine i've simiply left the parking lamp wires (purple with fuses) dis-connected at the moment.
Any help would be appreciated.
Luke.
