Car will not start due to fuel pump and injector is not running when key on or when crank. When you key on, the fuel pump never is started (like it ususally runs for few seconds and stops).
We have gone over the electrical / fuel system and determined that the fuel pump is functional but it is getting no power from the relay. The issue is NOT the inertia switch - no power there either.
Here is where it gets strange: if you put a few drops of gas down in the intake, the car will fire right up and then run fine. Ie. once the engine fires, the fuel pump and injector start running! If you shut it off and still have enough residual fuel in the intake, it will start again BUT if there is not enough fuel in there to restart, it won't fire. We powered the fuel pump directly to make sure there was constant pressure at the injector and it still would not start. So, neither the fuel pump or the injectors are starting when you crank the engine. But they start after the engine is running. Does this make any sense to anyone? Sprocket help!!!
Many thanks in advance.
Edited by Avl_Paul, 19 January 2008 - 07:20 PM.
