I will finish it one day. Honest!!!
My Mini Mojo Project 1.8 Vtec
Posted 23 January 2008 - 11:01 AM
Posted 23 January 2008 - 11:06 AM
did you do the frame yourself? I would like to know more about you car.
nice one.
Posted 23 January 2008 - 11:14 AM
I've welded a mini roll-cage over the top.
the body has 5" chopped out of floor.
the front end is 90mm longer, the wheelbase is 80mm longer than standard.
Posted 23 January 2008 - 11:34 AM
Posted 23 January 2008 - 02:47 PM
Posted 23 January 2008 - 05:00 PM
Posted 23 January 2008 - 05:38 PM
Posted 03 February 2008 - 09:59 AM
Posted 14 March 2008 - 08:02 PM
The chassis is a shortened Sylva Mojo chassis (kit car chassis)
I love the Mojo as a car in it's own right, but using it with a Mini shell over the top is pure genius! I guess using the Mojo, you have the option of all the Zetec ford engines, plus Honda and K series. Obviously using Ford fiesta hubs and shafts. Might consider doing that to my Smart!!! More progress and pix please?
Posted 18 June 2008 - 01:21 PM
Just fitted the rear alloy uprights!
They look the dogs!
The alloy uprights pull the hubs in further and the rear spats now fit!
Posted 18 June 2008 - 01:23 PM
Posted 18 June 2008 - 01:25 PM
Posted 18 June 2008 - 01:32 PM
Posted 18 June 2008 - 01:34 PM
Edited by Tomf, 18 June 2008 - 01:38 PM.
Posted 18 June 2008 - 01:35 PM
Have since cut 3mm steel plate to weld in, then bolt in the brake and clutch pedals.
Going to have a go at making my own accelerator pedal, i've already got the long accelerator cable from car builders solutions
