Mi cars in my garage at moment y i am wrking on it and ther is a lot of oil directly beneath the sump what could be the course of this ,and wen i check the dipstick there is no change in oil level its realy puzziling me lol
oil evry were???
dave 17
, Apr 01 2005 07:29 PM
8 replies to this topic
Posted 01 April 2005 - 07:29 PM
Posted 01 April 2005 - 07:34 PM
It normaly comes out of the hole where the gear stick rods go into the gear box
Posted 01 April 2005 - 07:42 PM
how much? a pudle or what? like bungle says minis are notorius for leakign oil at teh gear lincage but check the sump plugs tight!
Posted 01 April 2005 - 07:44 PM
well what do you want it's an classic english car. If they stop leaking you better check your oil level because you are probably out of oil. I wouldn't worry too much about it, unless it is a real puddle.
MiniMoi
MiniMoi
Posted 02 April 2005 - 09:58 AM
its quite a puddle but it has been der for at least 2 months so in comparison its not that much ,is the gear linkage connection at rear of engine and what can i do about it if that is the cause cheers
Posted 02 April 2005 - 08:22 PM
There is a kit available that is supposed to be better than the original, its pretty cheap and easy to fit. Have a look on the net for them. I presume minisport will do them.
pEaCE
Dom
pEaCE
Dom
Posted 03 April 2005 - 02:34 PM
iv just fitted mine from minispared, was about a fiver. U need to push the linkage pin out using a punch and disconect the linkage. then try to prie outthe old seals! i did it with tbhe engine out though and took the diff houseing off, it was much easier
Posted 04 April 2005 - 01:36 PM
Also check the diff output shaft oil seals, mine's pouring out of there at the moment.
Posted 04 April 2005 - 07:10 PM
kl cheers i have 2 get under and c wer bouts the oil actually is ,hard wen ders C**p all over it lol
