Rear Side Card Removal
Posted 23 January 2008 - 07:10 PM
I'll have the entire interior out of the car shortly (replacing carpeting, seat covers and all door furniture all in one go), so if something blocking the cards must be removed, it likely will be.
Thanks in advance for any assistance!
Posted 23 January 2008 - 07:16 PM
then just lift away
Posted 23 January 2008 - 07:28 PM
push the cards down and in in the middle and the top will drop out of the lip
then just lift away
Sounds simple when you say it that way... Wonder what others' problem(s) were? I'll take a look when I get my seats out - thanks!!
Posted 23 January 2008 - 07:35 PM
you need to tuck the card under the lip in the top, and if you have thick padded covered cards, it's a royal pain to get 'em in
Posted 23 January 2008 - 07:37 PM
Posted 23 January 2008 - 07:42 PM
I'm planning on using 1/8" Masonite or similar for the replacement cards, wrapped in leatherette. I'll try to keep the padding under the material to a minimum on the edges, based on the clearance of the clips. Sounds like a "3 beer job" at minimum.
Posted 23 January 2008 - 07:51 PM
Posted 23 January 2008 - 07:56 PM
however i took a bit more time getting the shiny new ones in
Posted 23 January 2008 - 08:09 PM
In my case getting them out was easy, i had new ones to go in, so went in and ripped em out in a few seconds, with no concern for them
Sounds like my nylon trim removal tools will finally come in handy in the classic.
