Had a little look yesterday once it stopped raining, got the grille off and found that its not coming from the oil pump (which I first thought) but from the timing cover. (I think thats what its called, the black cover the fan belts on above the oil pump, below the water pump?)
Lily, My '87 Mini Advantage.
#286
Posted 07 June 2009 - 09:40 AM
#287
Posted 07 June 2009 - 09:47 AM
#288
Posted 08 June 2009 - 08:31 PM
Shes going in on wednesday to have her exhaust sorted out, she sounds like a tractor at the mo!
Also I got told she sounds like a VW beetle, is that a good thing or a bad thing?!
#289
Posted 08 June 2009 - 09:12 PM
#290
Posted 09 June 2009 - 02:28 AM
#291
Posted 09 June 2009 - 09:14 AM
Bad! Air cooled racket!
Doh!
I reckon its the Gear selector seal
Is that around where you put the split pin in the gear linkage?
Shes leaking from there, but this is another leak!
Edited by sazal, 09 June 2009 - 09:16 AM.
#292
Posted 21 June 2009 - 11:58 AM
Ive not checked to see if she'll start yet
#293
Posted 02 July 2009 - 10:22 AM
He took the exhaust off and put it back on properly and hes spot welded it at the y piece to stop it coming off. Hes adviced me to get a 2nd engine steady (one thats on the later mins, so just gotta order that now
#294
Posted 02 July 2009 - 11:10 AM
Lily's getting the star treatment
#295
Posted 05 July 2009 - 06:45 PM
Ive not really been using her much with this oil leak, although it hadnt been affecting her and the dipstick level wasnt really moving. But took her for a bit of a drive yesterday and all was fine. Went to go out in her again later on and she was running really rough. Shes started dumping even more oil now.
Just need to find somewhere to take her to get it done cause the fellas given up on her.
#296
Posted 14 July 2009 - 07:58 PM
#297
Posted 16 July 2009 - 10:31 AM
#298
Posted 16 July 2009 - 11:39 PM
#299
Posted 17 July 2009 - 11:55 AM
She should be on my local clubs stand at the Crich Mini Show so if anyones there, keep an eye out for her!
#300
Posted 18 July 2009 - 01:05 PM
Went and picked her up this morning. Shes still leaking oil though as my mate tightened up the timing cover as the bolts were a bit loose, but the oils still coming through
Shes had a new set of leads fitted and some new spark plugs, also had to put a new dizzy cap on as there was a hole in the side of hers which was causing a misfire
Shes also had an oil and filter change and had some of the terminals (?) on her coil replaced as hers were looking a bit tired.
Got her grille back on so she doesnt looks sorry for herself anymore!
