Mpi Column Wiring Into Pre 96 Mini
Posted 28 January 2008 - 09:34 PM
so is it possible to tell we what wires do what so then i can work out for mine (94 mayfair) how to fit it in. its a cosmetic thing i'm notwanting the airbag to work (as it wont without the srs system)
any ideas as all i seem to be doing is going round in circles.
thanks
Bamby
Posted 06 February 2008 - 07:27 PM
Brown - First ignition position
White - Second Ignition Position
White and Red - Crank position
Wipers
This covers the wash, intermittent, slow and high...
Brown and Light Green - Slow wipe
Orange and Red - Intermittent wipe
Red and Light Green - Fast wipe
Light Green and Orange - goes to "flick switch one" whatever that is...
Blue and Light Green - goes to "flick switch 2" whatever that is...
Lights
Brown - power in
Red - Sidelights
Blue and Red - Dipped beam
Blue and White - Main beam
Blue - feed for the Rear Fog Lights
Indicators
Light Green and Brown - positive feed for indicators
Green and Red - Left Indicator
Green and White - Right Indicator
Airbag - doesn't affect carb minis and SPi but still useful to know what they are...
Yellow
Red
Horn
Black - Earth
Purple and Black - Live
I hope this helps... i've just drawn together a lot of time staring at the wiring diagram and this is how I perceive it...
Perhaps a mod could pin this??? seems like the kind of question that might get asked a few times???
Tom
Edited by tomsbluemini, 06 February 2008 - 09:12 PM.
Posted 10 February 2008 - 11:53 PM
I've just fitted the colum into my car today and was scratching my head with the wiring for the mpi stalks.
This will save me loads of time as i was sitting with a multi meter going through one by one.
Any chance you have what the wiring for the pre MPI stalks is too?
Cheers, Mark.
Edit....
My Accord has the exact same stalks as the MPI mini ones i'm fitting, and if the wiper system works the same, then the flick switch 1 is just like a regular flick wipe atthe normal speed, but if you hold the flick wipe in the Accord for longer than a second, it does a flick wipe at the fast speed, which might account for the flick switch 2?
Edited by M44K TS, 10 February 2008 - 11:57 PM.
Posted 11 February 2008 - 09:29 PM
Posted 11 February 2008 - 11:34 PM
i'm working on this at the moment haynes manual on lap...
got too tired going to finish it tomorrow...
I can PM it you you if you like or e-mail it to you tomorow if you need it???
Tom
Awesome!!!!!
Cheers, Mark.
Edit....
Posted 12 February 2008 - 03:43 PM
Just waiting on a new set of stalks then i can continue.
Details and pics of what i'm doing and how are in my project thread here......
http://www.theminifo...x...0&start=120
Basically, connecting the mpi plug in loom to the original so it just plugs in.
Posted 12 February 2008 - 04:36 PM
it's alright, got the wipers and indicator looms sorted, but the headlight switch is broken on my mpi stalks so i had a bit problem tracing out the wiring.
Bamby's stalk hasn't got any connectors, so it's splicing wires...
would be interested to know how you got your wipers to work...
Tom
Posted 12 February 2008 - 07:18 PM
but, i have some test gear i use for work which helped finding which wires short at the different positions. Basically for the wipers, the int. isn't going to be used as i don't have int. wipers, so that's being joined with the speed 1, then fast wipe is indepndant.
Posted 05 March 2008 - 10:09 PM
it is how mine is wired in, if anyone needs it explaining i can help just pm me.
Posted 05 March 2008 - 10:32 PM
what are "flick switch one" and "flick switch 2?"
Tom
Posted 06 March 2008 - 05:47 PM
Tom - flick wipe 1 and 2 is probably the same as what's in my accord. If you flick the wiper breifly, it'll do 1 sweep at the slow speed, but if you hold it in the flick position, it does the sweep at the faster speed. That's probably wired through a control unit though , but all i did was, I just wired mine to the faster speed for the flick wipe.
If anyone's having trouble tracing out which wire does what, i used some test gear i use for work (about £600 worth lol) to trace them all out, , and i have all the wiring diagrams/notes i made when doing mine so could re-write them as a guideon here for people to use?
Not sure about anyone else, but i've made it so that the new stalks use the plugs off the old ones so they just plug into the original loom of the car. Also, on the ignition barrell (if you're putting in the MPI one, all of the colours on the old and new match up, with the exception of the yellow which is connected to full ignition (position 2) and was probably used fo the fuel pump etc. I'll be using it as a feed for a ciggy lighter so it powers off when the ignition's off.
Edited by M44K TS, 06 March 2008 - 05:48 PM.
Posted 06 March 2008 - 05:53 PM
Posted 20 January 2010 - 08:28 PM
got mine in and working!!!!
I'm trying to do the same thing. Could I have a look at the diagrams you made please?
Posted 01 February 2010 - 04:07 PM
Can I just buy an MGF set of stalks and use them then? I hope so...
Posted 02 February 2010 - 08:29 PM
I'd really like to do this mod (to allow front fog switch on my 5 switch panel) - anyone have an answer?
Sorry - should have said - for a 1995 Mini Mayfair!
Edited by buffalox, 02 February 2010 - 08:30 PM.
