Looking For A Tax Exempt Mini? Read This First.
29 replies to this topic
#1 SolarB
SolarB
  • 1,387 posts
Posted 30 January 2008 - 04:55 PM
Like most people I will save money when I can and the thought of running a tax exempt Mini appealed to me. What could be better than avoiding this regular bill after years of paying more than £100 pounds annually for our pot holed roads? An added incentive was the use of black and silver number plates which happens to coincide with the pre 1973 cut off date for Historic Vehicle status, or tax exempt as most people call it. So I set out to buy a pre '73 car and entered a world full of re-shelled and ringed cars. I viewed four examples in the flesh and many more online. Out of the four cars viewed two were genuine, one had been re-shelled and the fourth simply had the VIN and number plates swapped from an earlier car. A number of the cars I looked at online were also non genuine. The desire to own a tax exempt Mini would appear to bring out the darker side in people.
A lot of people assume a Mini is a Mini and there is very little difference in body shells between years and maybe even decades, but they are wrong. After looking hard for a genuine car I've learned that there are many differences, some quite subtle, between early 1970s tax exempt shells and late 70s onwards. At the end of this post I've listed the differences between pre '73 body shells and later versions with the idea that anyone who has read this guide will have enough knowledge to spot the ringed or re-shelled vehicles.
Definitions: Re-shelling is transferring the majority of components and the identity from one car into a different body shell. Ringing is transferring of the identity of a car, usually by just swapping VIN and number plates.
To set things straight the re-shelling of a car with a secondhand shell is not illegal. It is allowed but must be declared to the DVLA, after which the vehicle will be the subject of an SVA test. If it passes the test it will be issued with a new registration number. The car will not retain its age, identity or tax exemption status as a historic vehicle. The use of a secondhand shell means the car cannot retain its original identity no matter how many of the original components are used in the replacement shell. The only way to re-shell a car and retain its identity is to use a new shell, currently produced by BMH for £3,600 (including bonnet, doors and boot).
So what does this mean to the potential buyer of a re-shelled or ringed car, and does re-shelling or ringing really hurt anyone except the tax man? The answer to this is yes, it hurts you, the new owner in several ways. If you buy one of these cars you'll almost certainly pay over the odds for the vehicle as tax exemption adds several hundred pounds to the value of a Mini. You may well not be insured as the car is not as declared to the insurance company. If you buy and drive a ringed or re-shelled car what do you do when it comes to selling it? Do you declare it to the DVLA and possibly write it off, or sell it on hoping the new owner doesn't find out, or more importantly, have an accident? If you're found out the police will want a word and the DVLA will want all the road fund license you've avoided paying over the years, plus a fine. I assume this holds true even after you've passed the car on to a new owner. DVLA aren't known for their sunny disposition and I believe its unlikely they will say "Lets forget about the 5 years road tax you evaded because someone else now owns the car". This means you'll never be rid of the thing once your name has been on the V5, it may come back to haunt you years later.
Which tax exempt model are you looking to buy? As a point of interest, to qualify for tax exemption the car must have been manufactured (not necessarily registered) before January 1st 1973. This means some cars registered in the first few months of 1973 may be eligible for historic vehicle status. The MkI and MkII cars (produced from 1959-1969) have external door hinges, sliding windows and are very different from later Minis. It is plainly obvious to most people if these are wrong. The MkIII is the version I'm talking about here and was produced between 1969 and 1976. There is of course a grey area, later MkIII cars ('73 to '76) have many of the features of the early MkIII '69 - '72 tax exempt vehicles. It is much harder to spot, say, a '71 car re-shelled in a '75 shell. MkIV cars were produced from 1976 onwards.
I've compiled a list of things to be aware of if you are looking at a tax exempt MkIII Mini ('69-'72). I've owned a couple of pre 1973 cars and numerous later models, the differences I've logged result from observation rather than detailed research, if I've made any mistakes please correct me. This is by no means a comprehensive list but it should give you a chance of spotting the car that is not genuine. The differences listed only apply to the shell itself as any component can be swapped over from the original vehicle, though many people don't seem to bother to swap even the most obvious of things. Finally, I wasn't looking at Clubmans, vans, estates or pickups and I believe some differences listed below don't necessarily apply to these models.
For the re-shelling or ringing of a MkIII model into a later shell you need to look at the following (listed roughly from front to back of the car):
Front subframe tower mounts. MkIII. Twin bolt mountings on the engine bay cross member.
[attachment=85959:Twin_bolt_1_a.JPG]
MkIV cars onwards have a large single bolt design.
[attachment=85958:Twin_bolt_2_a.JPG]
Front subframe lower rear mounts. The MkIII front subframe bolted directly to the bodyshell under the drivers and passengers feet. MkIV subframes have a rubber mount between the subframe and the body. Later car shown.
[attachment=85960:Subframe...unts_2_a.JPG]
Heater hose holes. MkIII heater hoses passed through the horizontal plate used to cover the clutch & brake master cylinder mounting holes for left hand drive cars. At some point in time later models were fitted with staggered oval holes above the cross member in the bulkhead. Later car shown.
[attachment=85961:LMP_12_small.JPG]
Cross member triangulation. All cars have a strengthening plate welded between the cross member and inner wing in the engine bay. MkIII cars have a small triangular hole and a couple of round holes in this plate. There are normally a few obvious spot welds holding the plate on.
[attachment=85962:LMP_14_small.JPG]
[attachment=85963:LMP_16_small.JPG]
MkIV cars have the triangular hole lengthened downwards turning the triangle into a rhombus, a tapped raised boss on the offside plate and four distinctive 1cm sized holes in the lower half of the plate exposing the cross member behind.
[attachment=85964:LMP_4_small.JPG]
Center binnacle captive bolts. In the engine bay MkIII cars have six captive square head bolts on the bulkhead and are used to secure the centre binnacle. Later cars fitted with instruments in front of the driver are missing the middle pair (3 & 9 o'clock position).
Front inner wheel arches. MkIII front wheel arches below the air vent hole are plain, later cars have a strengthening crease about 1" wide running from parcel shelf height to the floor. This can be seen by looking under the wheel arch. Later car shown.
[attachment=85965:P1020898_b.JPG]
Front subframe lower rear mount holes. The rear arms of the front subframe are fixed to the body with two bolts each. MkIII cars have one hole in the toe board and one hole in the floor on each mount, later cars have both mounting holes in the toe board.
[attachment=85966:Subframe...unts_3_a.jpg]
Gear lever hole. Earlier cars have a square hole for the gear lever in the exhaust tunnel biased towards the passenger, later cars have a larger rectangular hole in the center of the tunnel.
[attachment=85967:Gear_lever_1_a.jpg]
Exhaust tunnel. Earlier cars have a distinctive bulge on the drivers side of the exhaust tunnel next to the gear leaver, missing on MkIV and younger cars.
Cross member. MkIII cars have a step up from the front exhaust tunnel to the cross member. On MkIV cars the front exhaust tunnel is flush with the cross member.
[attachment=85968:LMP_11_small.JPG]
Handbrake. MkIII cars have a twin cable handbrake and twin adjusting nuts, one each side of the lever, the twin cables pass through their own holes in the floor. Later cars have a single cable on the handbrake lever, single cable hole in the exhaust tunnel and different handbrake mounting brackets. Later car shown.
Front belt mounts. MkIII cars have the front safety belt inertia reels mounted on the inner sills just in front of the rear bins. Later cars have the reels mounted inside the rear bins on distinctive welded in mounts. Later car shown which has both fixings.
[attachment=85969:Front_be...unts_2_a.JPG]
Ashtrays in rear pockets. MkIII cars have welded in ashtray mounts at the front of the rear bins (bringing the total ashtray count to four). These were deleted on later cars.
[attachment=85970:LMP_1_small.JPG]
Rear belt mounts. MkIII cars have no provision for rear seatbelts mounting points (though there are holes in the correct positions punched through the rear seat back).
[attachment=85971:LMP_5_small.JPG]
Later cars have strengthening bars in the boot with captive nuts.
[attachment=85974:LMP_18_small.JPG]
Later cars also have belt mounting points on the C pillars.
[attachment=85972:LMP_6_small.JPG]
Rear shelf speaker holes. MkIII cars have a pair of small holes for a single centre mounted oval speaker on the rear parcel shelf. Later cars have these small holes and a couple of large holes in the parcel shelf for larger speakers, one on each side of the original speaker. Over the years it's quite possible someone has cut holes for larger speakers. If these large holes have a return flange this means they have been stamped out in the factory, a giveaway that the parcel shelf is not an original MkIII panel.
Hole in rear seat back. MkIII cars have a large circular or oval hole punched in the centre of the rear seat upright. This will have a return flange on it. Later cars are missing this hole.
[attachment=85975:Rear_seat.JPG]
Roof gutter. Early cars have a horizontal slit in the roof gutter for drainage at each corner close to, but not directly above the vertical seam. Early cars also have a full length drip rail welded under the roof gutter on each side of the car.
[attachment=85976:Gutter_1_a.JPG]
Later cars have a square section of gutter missing directly above each vertical seam and no drip rail.
[attachment=85977:Gutter.jpg]
Panels may well have been replaced over the years, inner wings, boot floor, even a whole floor may be replaced but it's very unlikely that a car will loose all of its identifying marks. If the seller tells you every panel that had a distinctive trait has been replaced with later panels don’t believe him.
There are many other differences between Mk3 cars and later models including a smaller fuel tank, smaller square clutch and brake pedals, different switches and steering column. The heater front panel, dynamo, voltage regulator and interior trim along with a host of smaller items are different but these can all be changed. Remember, it is the shell that's important, not the components.
If you are after a tax exempt Mini good luck, they are out there and it's nice to have one, just don't get caught out. Once you've identified your genuine car and bought it enjoy it. To those of you who have read this purely out of interest have fun spotting the fakes.
Edited by SolarB, 05 June 2009 - 08:10 AM.
#2 charminbear
charminbear
  • 352 posts
  • Local Club: P&S
Posted 30 January 2008 - 05:15 PM
Good piece of info there.....
Just one possible mistake... The bottom rear seatbelt mounting holes, my 1980 Mini didnt have the captive nuts or strengthening bars.
I do believe these were only fitted from 1984 onwards (when the law changed and all cars had to have rear seatbelts)
#3 Jeff R
Jeff R
    The Forum Lesbian
  • 287 posts
Posted 30 January 2008 - 05:16 PM
Excellent guide
#4 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 30 January 2008 - 05:19 PM
I can see this being published in minimag soon, eh Jeff?? lol >_<
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 30 January 2008 - 05:26 PM
you haven't stated what the reshell rules were a few years ago before this tax exempt rules came in
about 20 years ago (might be a bit more) you could reshell a car and the dvla used a points system to see it it needed a Q reg or keep the cars original reg, at this time there were no SVA test's and i think you just needed a MOT
i don't know all the info but some up to date info to go with above would be nice if someone knows what the rules were
nice work >_<
#6 matminicity
matminicity
  • 787 posts
  • Local Club: T.M.F
Posted 30 January 2008 - 05:30 PM
Well done on producing such an informative guide.
I'll definately be looking closer in the future so i dont get caught out!
#7 Kernal H
Kernal H
  • 746 posts
Posted 30 January 2008 - 05:45 PM
My 1984 Mayfair (A reg) has all the holes and everything for seat belts, but does it actually need them for the MoT? I'm still in the process of getting everything ready but it would be nice to know.
#8 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 30 January 2008 - 06:02 PM
all the points you have listed are valid changes between early and later shells, BUT very few of them are actually related to the year 1973. Mk3 to mk4 change over was 1976.
so be careful, some but not all of these changes will be relevant depending on the age of the "new" shell.
for example and 1974 shell will be very similar to a 1973 one, but not taxed exempt >_<
Edited by THE ANORAK, 30 January 2008 - 06:03 PM.
#9 1984mini25
1984mini25
  • 8,785 posts
Posted 30 January 2008 - 06:32 PM
No it doesn’t need them in the back, although if they are fitted they still need to work properly, and if you plan to carry passengers it might be best to find some and fit them not only for their safety but also yours when they take a trip flying through the car towards the windscreen.
Although it’s some date around 86ish when the law changed and it was compulsory to have them fitted.
The thing that really gets me is it seams to be “Accepted� I could pick several features in both the mini mags of people who bought a tax-exempt mini to restore, then suddenly it was “too rotten� to repair and so they go out an buy another one and stick the vin pales from the tax-exempt mini as if its perfectly acceptable.
And a lot of people just see a mini as just a mini, not what year or mk it is, just a mini.
I don’t really like the idea of complete new heritage re-shells either, take the mini mag clubby for instance, really just how much of that was original?
2 clubbys striped for parts, brand new heritage shell, new complete built up front and rear sub frames, rebuilt 1300 engine, brand new interior, etc, etc. stick a couple of nameplates and stick the old vin tag on and your effetely got a brand new car trying to be something it isn’t.
#10 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 30 January 2008 - 06:52 PM
ha ha, that's a really good point >_<
#11 Kernal H
Kernal H
  • 746 posts
Posted 30 January 2008 - 06:59 PM
Cheers 1984mini25! I'm not planning on actually taking passengers in the back due to the 3" or so of leg room, but it's nice to know what's legal!
#12 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,145 posts
  • Name: Sean
Posted 30 January 2008 - 07:01 PM
Quote 1884 mini 25
[/quote]
Amen to that, its a real bug bear of mine, you see people with a "genuine cooper" that has been reshelled into a new shell with a new interior and an mg metro engine.
If you were planning to do this why not "save" an '80's mini and reshell it/fit 1380 engine/new interior and leave the cooper to be restored?
IMHO not many shells are "beyond restoration" and genuine stuff needs to be saved and not have their ID dilluted so they become and "original mop(that has had 2 handles and 4 new heads)!!"
Rant Over
Edited by shiftyseamus, 30 January 2008 - 07:02 PM.
#13 1984mini25
1984mini25
  • 8,785 posts
Posted 30 January 2008 - 07:11 PM
They only do it save paying road tax each year, which on a mini is what just over £100, not that much if you compare it to say how much you spend on making it look nice with new bits of trim, wheels, seats etc. and the extra value it now has over other minis which aren’t tax exempt.
I know most people probably won’t like this, but seeing as it’s �accepted� even though it is illegal it do this, why not just scrap the tax-exemption for cars built before 73 and make every one pay, that way there won’t be any point in doing it.
#14 Shifty
Shifty
  • 13,145 posts
  • Name: Sean
Posted 30 January 2008 - 07:31 PM
Not sure about this(mainly because I've got a tax exempt mini) >_<
I have to admit that that hasn't got its original shell, however it was changed before I got it.
I didn't want to alter the cars history even further by changing the shell again so I decided to repair the "original" very very rusty shell(see my project thread - is this the rustiest mini in the world)
#15 redhotmini
redhotmini
  • 1,607 posts
Posted 30 January 2008 - 07:36 PM
also if you were to reshell a tax exempt mini with a heritage shell (which is acceptable), then that also messes things up as you can't get the early mk3 shells from heritage, only mk4 onward shells.
