I was under the impression a resister would suffice 'n would have thought one would be built in if the bulb is intended for 12volt auto application.
If you do go with a voltage regulator why not step it down even further, say 5-6v to guarantee the battery will always supply more than the leds need?
Because at 5-6V the LED's I want to use won't have enough power, might try and find some lower voltage ones and then it would work.
hmm.... sounds like you arnt using LEDS on their own as an LED is just a Light Emmiting Diode..... IE its just a PN junction that emmits light when transmitting a current. They dont have a 'resistance' as such. from what you are describing you have a system that already has the additional electronixcs and resistors in place inside the housing. and just need a regulator to prevent the voltage from going too high. If I was doing this Id layout my own cct from scratch, but you look like you have a module you want to use. If your thinkin of using something like a 7812 V reg then its rating is only about 1A supply anyway. If you try to drop down to 5 volts you will draw more current and also the reg will overheat dropping the 7 odd volts....
Just a note... the LED resistance isnt 10R your module might have a percieved impedance of x ohms but I thibnk thats more likly to be with additional cct in the module.
No the LED's come packaged as an automotive bulb, so you would have thought they would be able to cope with over 12V, but like I say I have seen ones that have burnt themselves out suggesting they can't deal with limiting voltage/current themselves.
The voltage regulator is similar to the 7812 but has a lower voltage drop across it and a higher current. The ID is KA278R12C.
Assuming that I want to use pre-packed LED bulbs, what would you see as the best way to ensure I always give them full power without damaging them?
