Is It The Timing On My Mpi?
Posted 04 February 2008 - 09:23 PM
So here's my problem: Fuel consumption up, top speed and acceleration slightly down, also a very cool (although probably not good) loud burbling exhaust noise on deacceleration.
Is my timing out?
If so how do i adjust it?
I have done timing before, but on various VW beetles and campers (my girlfiend converted me to mini's from the aircooled scene, haven't looked back!), but they never had ECU's!
I think it probably is timing,but this Rover ECU's and its sensors is bothering me. I've heard there very sensitive and can be very expensive if they go wrong.
A little help would be great.!
Posted 05 February 2008 - 11:53 PM
are there any other symptoms? is it getting warmer than usual, is the coolant fan running all the time, any stalling issues or sputter/bucking. is it idling at its normal point? possibly leaking valve would explain the symptoms, can you do a compression test or a leakdown test to elminate a possible valve problem
Edited by elvisthepizzaman, 05 February 2008 - 11:56 PM.
Posted 06 February 2008 - 12:53 AM
Posted 14 February 2008 - 09:32 PM
Elvis i've been suffering majority of those problems, done a compression test and the readings are as follows:
C1 192
C2 188
C3 155
C4 190
So any ideas on sorting it out would be cool. Its getting louder everytime i drive it.
I have a K&N Fitted. How do i clean a K&N?
Thanks guys.
Posted 14 February 2008 - 09:43 PM
You're suppost to use official K&N cleaner products, but you can just use some oil and a rag to clean out each of the slots in the filter.
Posted 15 February 2008 - 02:43 AM
what are your other symptoms that you say you have? more details..
Edited by elvisthepizzaman, 15 February 2008 - 02:49 AM.
Posted 17 April 2008 - 09:26 PM
Posted 18 April 2008 - 12:28 PM
Posted 18 April 2008 - 06:53 PM
Sensors arn't expensive. Pop down your local scappy with various spanners and wire cutters and set about any post 96 rover. They're universal across the range. Also have a good check all around the exhaust and manifolds, you might find a good excuse for an upgrade.
Its usually good practice to buy new sensors, which are not that expensive new, buying sensors from a scappy means you dont know if they are faulty. Buying sensors new gives you confidence that they will work.
Paul.
Posted 13 May 2008 - 11:30 PM
Posted 14 May 2008 - 10:33 PM
