Repair To Rust Bubble
4 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 08 February 2008 - 05:33 PM
Hi
I now have a 200 Cooper Sport in British racing green pearlescent. I have a small rust bubble on the edge the cowl about the size of a 5p piece. Because the paint is pearlescent BRG, can I fix this myself, or is it best left to a garage?
Does a paint shop do this type of thing?
The car is otherwise in perfect new condition and I don't want to make it worse! Thanks
John
#2 mike49
mike49
  • 973 posts
Posted 08 February 2008 - 06:02 PM
go at the bubble and see if its a hole or just a bit or surface first
#3 mk=john
mk=john
  • 1,167 posts
Posted 08 February 2008 - 06:25 PM
Hi
I will look tomorrow, but if it is surface rust (which i am sure it is) what is the best course of action considering this is BRG pearlescent?
#4 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 08 February 2008 - 09:22 PM
The colour/type of paint makes no difference really as to how to rectify the problem, the process is the same for whatever colour. Bare metal the area, remove as much of the corrosion as possible, apply rust eater, followed by a skim of good quality body filler, zinc prime the bare metal areas remaining around the edge of the filler, prime as normal, prep and paint. Once rust has started, there is no way of stopping it entirely, the only way is to replace the panel, or cut it out and weld in a patch, but that's not ideal, if you value the originality of the car.
#5 1984mini25
1984mini25
  • 8,785 posts
Posted 09 February 2008 - 09:46 PM
Think your more concerned with the paint match/touch up after the rust has been dealt with, if so unless you’re really good, metallics/pearls are the worst colours to spray/match at home.
