Supercharger Mpg
8 replies to this topic
#1 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 11 February 2008 - 11:38 PM
Hi,
Just wondering whats the mpg like with a supercharger fitted ?
thanks !
#2 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 12 February 2008 - 09:42 AM
As with any modification it will depend how you drive the car really. You could drive it really sensibly and not rev it at all, but then whats the point of fitting a supercharger in the first place ?
How you gear the supercharger will play a big role, if you're constantly on boost obviously the fuel consumption will be heavy. Generally engines built for forced induction also have poor part throttle economy due to using low compression ratios.
Baically if your really bothered about real economy, DONT fit a Turbo or Supercharger.
#3 Wil_h
Wil_h
  • 3,244 posts
Posted 12 February 2008 - 10:07 AM
If you want economy AND power your best bet is a high (relitively) CR turbo. From what others have said, typical mpg for supercharged engines is around 25, my turbo easily does 40.
#4 mininutter
mininutter
  • 46 posts
  • Local Club: Eastbourne - EDMC
Posted 13 February 2008 - 09:54 AM
15-25mpg with a bit of noisy peddel action. 70mph motorway crusie should give you 40mpg but not much more.
But thats an Vmax Scart MPI setup with a 2.7 final drive, an Emerald ECU and wideband lambda sensor, ££££.
Not sure what the carb setup's are getting.
#5 Supercharged_clubby
Supercharged_clubby
  • 131 posts
  • Local Club: Skegness mini owners club
Posted 13 February 2008 - 02:07 PM
mine does 18mpg on a normal daily drive on back roads.... 20-25 on a motorway run.
#6 mininutter
mininutter
  • 46 posts
Posted 13 February 2008 - 05:30 PM
Ouch! What setup do you have?!?
#7 TheKing777
TheKing777
  • 153 posts
Posted 18 February 2008 - 10:56 AM
Great, I've got all this to look forward to, the supercharger is in, just finishing off the final things like hte starter motor and facet. Probably get less mpg than my bros audi s8 :S
#8 Ethel
  • 26,104 posts
Posted 18 February 2008 - 11:38 AM
Really does depend a lot on how you drive, the Mini is a light car 'n even if it has the streamlining of a brick it still only punches a little hole through the air. The Turbo Metro had better MPG than the MG, mostly because it could pull a higher diff since it made more torque.
#9 coopertrooper2001
coopertrooper2001
  • 104 posts
Posted 12 May 2008 - 06:34 PM
MPi conversion with Emerald and Wideband lambda.
I get about 28 MPG around town - giving it some every now and then. I can get 32 if I drive it like Miss Daisy.
