Decompression Plate
14 replies to this topic
#1 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 15 February 2008 - 06:30 PM
Hi,
Can a decompression plate as fitted when doing a supercharger conversion be put onto a non turbo 1275 when installing a turbo ?
thanks !
#2 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 15 February 2008 - 07:09 PM
they can yeah, not the best way of doing it though to be honest. most would class it as a bodge.
#3 insamoufonyx
insamoufonyx
  • 1,633 posts
  • Local Club: NorthSomersetMiniClub.co.uk
Posted 23 February 2008 - 07:18 PM
stupid question but what is a decompresion plate?
cheers
#4 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 23 February 2008 - 07:48 PM
its like a thick headgasket made froma sheet of metal to space the head away from the block which lowers the compresion ratio
#5 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 23 February 2008 - 07:50 PM
you'd be better off with the head built for the job i'd reckon.
#6 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 23 February 2008 - 07:54 PM
The easiest way to lower the compression is to have the chambers opened up.
#7 mini13
mini13
  • 3,811 posts
Posted 23 February 2008 - 08:19 PM
Yep best to open up the chambers,
then if you need to change the headgasket you'll only need one!
I think the only time a decompression plate is worthwile is if you are converting an mpi and may want to take everything back off in the future.
#8 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 23 February 2008 - 08:26 PM
Agree with all of above. ^^^^
I would think by the time you've bought the decomperssion plate and 2 gaskets you could get your chambers enlarged!
#9 Gavin Wakely
Gavin Wakely
  • 11 posts
  • Local Club: Milton Keynes Mini Owners Club
Posted 28 February 2008 - 12:56 PM
Hi,
thanks !
I'm sure Minispeed do 2 types of decompression gasket, so no need for 2 gaskets and a decompression plate (ie thick gaskets)
No sure if they are any good but they sound better than a decompression plate.
#10 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 29 February 2008 - 02:48 AM
yeah i've seen those advertised, something £120 for a 120thou gasket, cheaper to have the chambers opened up in the head.
#11 1963MKI
1963MKI
  • 163 posts
Posted 13 March 2017 - 01:37 PM
im rebuilding my austin 1300gt engine +20 thou and was thinking would just using the 8.8 cr ratio pistons instead of the 9.7 ones that the engine had standard negate the need for the compression plate ?
#12 mini13
mini13
  • 3,811 posts
Posted 13 March 2017 - 06:59 PM
Pretty sure the 8.8:1 pistons are made of cheese, the 9.7's might not be too much better either, find out what the part nos are and do a search
#13 1963MKI
1963MKI
  • 163 posts
Posted 14 March 2017 - 10:33 AM
the 9.7 ones are the 21253 + 20
#14 mini13
mini13
  • 3,811 posts
Posted 14 March 2017 - 10:42 AM
They would be OK then
#15 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 17 March 2017 - 09:18 PM
there's also enough meat in the 21253's to machine the dish bigger to drop your CR
