Running A Dry Sump?!
5 replies to this topic
#1 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 18 February 2008 - 03:33 PM
Right was lookin at a cam description and it read;
"the cam also has the pinion for driving a dry sump set up, but is perfectly usable in a normal wet sump set up"
Is it actually possible to run a dry box/sump!?! I was a little confused as the block shares its oil with the box.
Docs?? :wub:
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 18 February 2008 - 03:41 PM
Not in a Mini type engine but two possibilites come to mind. Either the write up was by someone who has never seen a cam with a distributor gear on (few engines still drive the dizzy this way after all) and that is the gear he was talking about. Or the cam is also designed for in-line type racing A series engines used in Spridgets and other cars and somebody has designed a dry sump system for those engines which somehow manages to cram a scavenger drive onto the camshaft. Myself I'd bet on the first option as it would be pretty expensive to retool a cam like that just to run a dry sump when you could run the pump in other ways.
#3 mini13
mini13
  • 3,811 posts
Posted 18 February 2008 - 04:23 PM
aparently there are(were) some A series cams about that had what looked a dizzy drive gear where the fuel pump lobe would be.
as said theyu were for inline engines.
#4 Dusky
Dusky
  • 5,322 posts
Posted 03 January 2014 - 12:13 AM
www.theminiforum.co.uk/forums/topic/271915-different-fuel-pump-drive-camshaft/
Like mine here :P
#5 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 03 January 2014 - 09:47 AM
You can run a mini engine dry sump
Separate the gearbox and engine, tap into the oil feeds for a pressure in / out and to a scavenge pump, to the tank:). You could in better gearbox oil too:D
#6 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 03 January 2014 - 07:19 PM
So how would you separate the drop gears from the engine block/crankshaft?.
