Performance coil?
Posted 11 April 2005 - 09:57 PM
thanks
Posted 11 April 2005 - 09:59 PM
Posted 11 April 2005 - 10:07 PM
i guess it just goes in place of the old one? The only thing i suppose could go wrong is if you try to take the coil bracket off and it is secured directly by a cylinder head nut rather than by a separate nut on top of the head nut but on the same stud, and then you end up loosening 1 head stud all the way to take the coil bracket off which would not be good as head nuts should be loosened in the right order. On my latest mini this was the way the coil had been mounted...
Posted 11 April 2005 - 10:10 PM
make sure the + & - dont get mixed up on the wires going to the coil
Posted 11 April 2005 - 10:15 PM
Posted 11 April 2005 - 10:32 PM
Posted 11 April 2005 - 10:33 PM
electronic
Posted 11 April 2005 - 10:34 PM
if so you'll need an electronic ignition coil, or take your red bull cover off and put it on the coil you already have fitted. Like I said though, be careful of the coil overheating.
Posted 11 April 2005 - 10:37 PM
Posted 11 April 2005 - 10:40 PM
Posted 11 April 2005 - 10:42 PM
did you not say the age of the mini when you bought the coil ?
Posted 11 April 2005 - 10:50 PM
Posted 11 April 2005 - 10:52 PM
