20 Valve Turbo 4age
Posted 20 February 2008 - 12:40 AM
Posted 20 February 2008 - 03:31 AM
the ONLY way you could better this is to make it rwd
Posted 20 February 2008 - 05:35 AM
Posted 21 February 2008 - 05:14 AM
Costs so far (NZ$2.4 = about 1 pound)
Levin for transplant with engine, drivetrain and all brakes $300
Mini 1000 in reasonably tidy condition (no rust) $1000
Cheap so far at about 540 pound
Posted 21 February 2008 - 10:42 AM
What sort of suspension setup are you going to use?
Posted 21 February 2008 - 09:54 PM
You Jammy sod!
Im not actually all to sure yet, was actually hoping for some advice on what other people have found to be good set ups? Would like to put in coil overs but do you usually take out the hydrolastic suspension when you put the coil overs in or just leave it to make it rigid like a rock?
Measured up for cutting out the wheel arches and new flares. A set of mk1 escort works rally arches should give enough space to allow a set of 17x7s front and rear.
Also anyone got any quick pointers on where to start for lightening the car? carbon bonnet, boot and a striped interior what im aiming at so far. Want it weighing around 600kg. I know the engine, trans and turbo weighs about 160kg and the levin discs and hubs weigh the same as the mini hubs and drums coming off.
Posted 24 February 2008 - 10:27 PM
Posted 25 February 2008 - 05:38 PM
as for lightening, carbon roof, boot, bonnet, flipfront, boot floor, alloy door skins, polycarb windows
good luck with the project!
Posted 11 March 2008 - 12:31 PM
start by chipping off all the sound deadening from the floor, and cutting the rear bins out
?do you usually take out the hydrolastic suspension when you put the coil overs in or just leave it to make it rigid like a rock
Take it out... there's no use for it once the coilovers are in
Posted 30 March 2008 - 04:38 AM
Posted 30 March 2008 - 10:33 AM
i think 585 has been found with a cage, the front end being changed the boot and the roof skin only. oh and slidey windows
however you could get carbon doors parcel shelf boot floor, rear valance. whole front end and bumpers.
