Hi all
Today, as i was driving, the speedo needle was bouncing especially between 50 and 60mph... and progressively got worst...
and eventually just died! Now i got no speedo...
What happened?
Syed
Malaysia
Centre Speedo Needle Bounce, Then Died.
Syed Malaysia
, Feb 20 2008 10:09 AM
6 replies to this topic
Posted 20 February 2008 - 10:09 AM
Posted 20 February 2008 - 10:27 AM
The cables snapped most likely.
When refitting the new one make sure no real sharp bends in the cable, keep the bends as long as possible
Posted 20 February 2008 - 01:11 PM
As stated above, start with the cable as the most likely cause.
However, if the needle was bouncing and then suddenly pegs (and subsequently stays) all the way to the right... that indicates a serious problem inside the gauge.
Posted 20 February 2008 - 01:52 PM
OK thanx. will have a look tomorrow. As for the needle staying to the right, no its not. It stays at Zero...
Now if i can just get a new centre speedo cable cheapish in Malaysia...
Posted 20 February 2008 - 03:13 PM
Check the cables pushed properly into the back of the gauge first. If you didn't get it all the way in before then it might of just fell out.
Posted 20 February 2008 - 03:56 PM
iv'e heard that if the needles bounce it indicates that the coil is on its way out?? thats just what iv'e heard, but feel free to correct me if im wrong
bb
bb
Posted 20 February 2008 - 04:03 PM
I doubt needle bounce as anything to do with the coil on the speedo, theres no electrical connection unless you count the dial illumination
Your probably thinking of the tachometer (rev counter)
