Hi, ive recently stripped my engine out and im now painting the subframe and ive noticed the bump stops are missing/ broken!
Should i get new ones or are you safe without them?
Thanks!
Removing Bump Stops?
BLING_IAN
, Feb 20 2008 07:46 PM
4 replies to this topic
Posted 20 February 2008 - 07:46 PM
Posted 20 February 2008 - 08:25 PM
Get new ones, they won't be expensive and are easy to fit and its useful not to have the suspension smash into itself if you hit a big old bump.
Posted 20 February 2008 - 10:11 PM
Yer bumpstops are very cheap in fact i have a spare pair!
They are a small but pretty essential to Suspension Longevity and ride comfort.
Which bump stops have gone? top or bottom?
They screw in, so are easy to install and uninstall!
Hope this Helps
Alastiar
Hope this Helps
Alastiar
Posted 21 February 2008 - 12:31 AM
Unfortunately that isn't what happens first. Before the suspension hits the subframe the balljoint pin will reach the limit of its travel, flex against its housing and start to fatigue, one day it will snap without warning and the suspension will collapse completely in that corner. Bump stops are essential and if your car has been running for any length of time without them I would strongly suggest that you replace the balljoints.
Edited by Dan, 21 February 2008 - 12:31 AM.
Posted 21 February 2008 - 08:24 PM
Right ive ordered bump stops and poly bushes. i jus thought i could get away without the bumpstops! thanks for your help!
