Indicators 1 Side Flashes And The Other Doesn't
8 replies to this topic
#1 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,147 posts
  • Name: Sean
Posted 25 February 2008 - 08:39 PM
Really as the title says, The indicators on my car only flash on one side, I have replaced the flasher and still no joy.
I have had a look at the Haynes diagram and suspect that the hazzard warning switch may be at fault?
Also confession time!!! :(
Whilst removing the front wings I got a bit carried away with the drill and caught the loom!!!!
There were a few sparks but I have stripped the loom back and repaired the loom as necessary.
Oh yeah, its a H plate Cooper
Any Thoughts
Seamus
#2 panelbeaterpeter
panelbeaterpeter
  • 5,606 posts
  • Local Club: n/a
Posted 25 February 2008 - 08:42 PM
Mine were doing that, I cleaned up the connectors leading to each individual indicator unit and they worked again.
#3 Mayfair85
Mayfair85
  • 268 posts
Posted 25 February 2008 - 08:49 PM
My left hand ones stopped flashing and when I looked under the bonnet it turned out that some of the wires had come loose, got hooked on the bonnet catch and been pulled onto the alternator where they'd been shredded. I just whipped a connector on there and zip tied them back.
Just an idea.
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 25 February 2008 - 08:54 PM
the hazzard switch does cause problems
when you turn the hazzard switch on do all the lights light up ?
#5 v8mini
v8mini
  • 726 posts
  • Local Club: Minis on the run
Posted 25 February 2008 - 08:56 PM
if all bulbs are working, i could be due to a bad earth or connection
#6 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 25 February 2008 - 09:01 PM
The hazzards do work correctly, the passengers side works fine off the switch.
The car was fitted with a crappy cheapo home fitted alarm, so I took that out - still no joy!!
The drivers side front indicator doesn't light at all, just the wing repeater and rear.
I will double check all of the connections tomorrow evening.
I have a suspicion that when I drilled the loom it fried the Hazzard switch?
Seamus
#7 yorkshirechris
yorkshirechris
    11.11.11
  • 3,873 posts
  • Local Club: www.lcmoc.com
Posted 25 February 2008 - 09:03 PM
You may as well start with checking wires aren't corroded/earthing because that's the cheapest start. Then start looking at the hazard switch, and flasher units. It can't really be anything else :( maybe a tired battery? As a last resort. My indicators wouldn't flash normally, they'd just stay on for about 5 seconds then flicker off and back on... and after replacing the battery they worked fine.
#8 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 25 February 2008 - 09:04 PM
it every thing lights up with the hazard switch then it can't be a dodgy earth or the wiring to the indicators
i would replace the switch
#9 Shifty
Shifty
  • 13,147 posts
  • Name: Sean
Posted 25 February 2008 - 09:08 PM
Thats a good point!!!!
I can't nick one off my other Mini because its too early to need hazzards!!
Might pop over to my bro in laws and pinch his :(
Thanks everyone for your help
Seamus
